[petsc-dev] cmake 2.8-10.1 failing on my mac
Wed Nov 7 22:59:00 CST 2012
   Yup this also works on Mountain lion with the latest Xcode. Must be something about the .dmg Mac specific Application build that fucks it up.
    No worries, I've just backed out to using the the older version for my work.
    BTW: whoever added support for --download-xxx=http:   thanks!
   Barry
On Nov 7, 2012, at 10:32 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> I attempted --download-cmake=http://www.cmake.org/files/v2.8/cmake-2.8.10.1.tar.gz on linux and osx 10.6 and
> that went through fine..
>> Could not read file /Users/barrysmith/Src/petsc-dev/arch-test/CMakeCache.txt: IOError(2, 'No such file or directory')
> I'm not sure what this means. Jed might have ideas.
> Satish
> On Wed, 7 Nov 2012, Barry Smith wrote:
>>   I upgraded cmake on my mac and now configure hangs will running cmake. If I kill the cmake process I see the following in configure.log
>>    When I use --download-cmake and it gets the old version then that runs fine. Has PETSc's cmake stuff been tested with 2.8-10.1?
>>   Barry
>>        Pushing language C
>>        Popping language C
>> sh: ['/usr/bin/cmake', '--version']
>> Executing: ['/usr/bin/cmake', '--version']
>> sh: cmake version 2.8.10.1
>>            Pushing language C
>>            Popping language C
>> Invoking: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
>> sh: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
>> Executing: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
>> sh: Running with trace output on.
>> Running with debug output on.
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>> -- Configuring done
>>                  CMake setup incomplete (status 9), falling back to legacy build
>>      CMake configuration was unsuccessful
