[petsc-dev] cmake 2.8-10.1 failing on my mac
Wed Nov 7 21:32:29 CST 2012
   I upgraded cmake on my mac and now configure hangs will running cmake. If I kill the cmake process I see the following in configure.log
    When I use --download-cmake and it gets the old version then that runs fine. Has PETSc's cmake stuff been tested with 2.8-10.1?
   Barry
        Pushing language C
        Popping language C
sh: ['/usr/bin/cmake', '--version']
Executing: ['/usr/bin/cmake', '--version']
sh: cmake version 2.8.10.1
            Pushing language C
            Popping language C
Invoking: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
sh: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
Executing: ['/usr/bin/cmake', '--trace', '--debug-output', '/Users/barrysmith/Src/petsc-dev', '-DCMAKE_C_COMPILER:FILEPATH=gcc', '-DCMAKE_C_FLAGS:STRING= -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0', '-DCMAKE_AR=/usr/bin/ar', '-DCMAKE_RANLIB=/usr/bin/ranlib']
sh: Running with trace output on.
Running with debug output on.
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
-- Configuring done
                  CMake setup incomplete (status 9), falling back to legacy build
Could not read file /Users/barrysmith/Src/petsc-dev/arch-test/CMakeCache.txt: IOError(2, 'No such file or directory')
      CMake configuration was unsuccessful
