[petsc-dev] Iteration counter depends on KSP monitor!
Thomas Witkowski thomas.witkowski at tu-dresden.de
Wed Nov 7 12:55:28 CST 2012
Okay, the outer KSP is as follows:
KSP Object:(ns_) 2 MPI processes
   type: fgmres
     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
     GMRES: happy breakdown tolerance 1e-30
   maximum iterations=100, initial guess is zero
   tolerances:  relative=1e-06, absolute=1e-08, divergence=10000
   right preconditioning
   has attached null space
   using UNPRECONDITIONED norm type for convergence test
PC Object:(ns_) 2 MPI processes
   type: fieldsplit
     FieldSplit with Schur preconditioner, factorization FULL
     Preconditioner for the Schur complement formed from the block
diagonal part of A11
     Split info:
     Split number 0 Defined by IS
     Split number 1 Defined by IS
     KSP solver for A00 block
       KSP Object:      (velocity_)       2 MPI processes
         type: richardson
           Richardson: damping factor=1
         maximum iterations=1, initial guess is zero
         tolerances:  relative=0, absolute=1e-14, divergence=10000
         left preconditioning
         using PRECONDITIONED norm type for convergence test
       PC Object:      (velocity_)       2 MPI processes
         type: hypre
           HYPRE BoomerAMG preconditioning
           HYPRE BoomerAMG: Cycle type V
           HYPRE BoomerAMG: Maximum number of levels 25
           HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
           HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
           HYPRE BoomerAMG: Threshold for strong coupling 0.25
           HYPRE BoomerAMG: Interpolation truncation factor 0
           HYPRE BoomerAMG: Interpolation: max elements per row 0
           HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
           HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
           HYPRE BoomerAMG: Maximum row sums 0.9
           HYPRE BoomerAMG: Sweeps down         1
           HYPRE BoomerAMG: Sweeps up           1
           HYPRE BoomerAMG: Sweeps on coarse    1
           HYPRE BoomerAMG: Relax down symmetric-SOR/Jacobi
           HYPRE BoomerAMG: Relax up symmetric-SOR/Jacobi
           HYPRE BoomerAMG: Relax on coarse Gaussian-elimination
           HYPRE BoomerAMG: Relax weight  (all)      1
           HYPRE BoomerAMG: Outer relax weight (all) 1
           HYPRE BoomerAMG: Using CF-relaxation
           HYPRE BoomerAMG: Measure type        local
           HYPRE BoomerAMG: Coarsen type        Falgout
           HYPRE BoomerAMG: Interpolation type  classical
         linear system matrix = precond matrix:
         Matrix Object:         2 MPI processes
           type: mpiaij
           rows=2754, cols=2754
           total: nonzeros=25026, allocated nonzeros=25026
           total number of mallocs used during MatSetValues calls =0
             not using I-node (on process 0) routines
     KSP solver for S = A11 - A10 inv(A00) A01
       KSP Object:      (ns_fieldsplit_pressure_)       2 MPI processes
         type: preonly
         maximum iterations=10000, initial guess is zero
         tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
         using NONE norm type for convergence test
       PC Object:      (ns_fieldsplit_pressure_)       2 MPI processes
         type: shell
           Shell: no name
         linear system matrix followed by preconditioner matrix:
           type: schurcomplement
           rows=369, cols=369
             Schur complement A11 - A10 inv(A00) A01
             A11
                 type: mpiaij
                 rows=369, cols=369
                 total: nonzeros=0, allocated nonzeros=0
                   using I-node (on process 0) routines: found 33 nodes,
limit used is 5
             A10
                 type: mpiaij
                 rows=369, cols=2754
                 total: nonzeros=8973, allocated nonzeros=8973
             KSP of A00
processes
                 type: richardson
processes
                 type: hypre
hypre call 1
coarsening 0
coarsening 1
                   type: mpiaij
             A01
                 type: mpiaij
                 rows=2754, cols=369
                 total: nonzeros=7883, allocated nonzeros=7883
           type: mpiaij
           rows=369, cols=369
             using I-node (on process 0) routines: found 33 nodes, limit
used is 5
     type: mpiaij
     rows=3123, cols=3123
     total: nonzeros=41882, allocated nonzeros=52732
Note that "ns_fieldsplit_pressure_" is a PCShell. This make again use of
two KSP objects "mass_" and "laplace_"
KSP Object:(mass_) 2 MPI processes
   type: cg
   maximum iterations=2
   using nonzero initial guess
PC Object:(mass_) 2 MPI processes
   type: jacobi
     type: mpiaij
     rows=369, cols=369
     total: nonzeros=2385, allocated nonzeros=2506
AND
KSP Object:(laplace_) 2 MPI processes
   type: richardson
PC Object:(laplace_) 2 MPI processes
   type: hypre
     type: mpiaij
     rows=369, cols=369
     total: nonzeros=1745, allocated nonzeros=2506
The outer iteration count is now influenced when adding
"-laplace_ksp_monitor" to the command line options.
Thomas
Am 07.11.2012 19:49, schrieb Barry Smith:
>      This is normally not expected but might happen under some combination of solver options. Please send the output of -ksp_view and the options you use and we'll try to understand the situation.
>     Barry
> On Nov 7, 2012, at 12:12 PM, Thomas Witkowski <thomas.witkowski at tu-dresden.de> wrote:
>> I have a very curious behavior in one of my codes: Whenever I enable a KSP Monitor for an inner solver, the outer iteration count goes down from 25 to 18! Okay, this is great :) I like it so see iteration counts decreasing, but I would like to know what's going on, and eventually, a KSP monitor should not influence the whole game. An to answer your first question, I run the code through valgrind and its free of any errors. Any idea what to check next? Thanks for any advice.
>> Thomas
