[petsc-dev] Current status: GPUs for PETSc
Sun Nov 4 21:07:47 CST 2012
On Sun, Nov 4, 2012 at 10:04 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
>      The copy_to_cpu-part could be managed via page-locked memory, yet I
>>     still have to investigate its robustness. It is certainly a nice
>>     option for APUs, because it has zero overhead. The only drawback is
>>     that APUs just lack performance in general...
>>     Overall, I don't want to give away the robustness you described
>>     above. There will always be some operations that work better on the
>>     CPU, while others work better on accelerators, so hopping between
>>     them is (unfortunately) rather the rule than the exception in real
>>     world applications.
>> Okay, then I have a procedural question. Should we write about this for
>> the GPU book, or just describe the
>> current state of affairs?
> Considering that I wanted to contact you anyway with respect to help on
> the write-up for the book: Can we postpone this decision to around November
> 20th? I guess I will have have a much clearer picture on the topic then.
Yes, I think we can writeup the old stuff in time for mid-Jan, so waiting
does no harm.
    Matt
> Best regards,
> Karli
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20121104/a5a68580/attachment.html>
