[petsc-dev] What needs to be done before a release?
Blaise Bourdin bourdin at lsu.edu
Thu May 31 12:21:49 CDT 2012
Is this a real or potential issue? C interoperability has been implemented in all compilers I know of for a while.
In 2007, cray, gfortran, g95, intel  and NAG already supported this functionality. http://dx.doi.org/10.1145/1243413.1243414
The current version is at http://dx.doi.org/10.1145/2073761.2073762 (I wish it would also give the earliest release each feature was implemented).
For those who don't use fortran and may not have a "recent" compiler, there is always --with-fortran=0
Blaise
> Barry is looking at using this flag and reorganizing the f2003 code.
> [perhaps the interface functions that need this functionality won't be
> compiled selectively - based on this flag]
> Satish
> On Thu, 31 May 2012, Jed Brown wrote:
>> So how do we deal with this function not being implemented unless an F2003
>> compiler is used? Just #ifdef its body and produce a run-time error when an
>> old compiler is used? Satish, are you doing this?
>> On Thu, May 31, 2012 at 11:36 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> Added configure check.
>>> http://petsc.cs.iit.edu/petsc/releases/BuildSystem-3.3/rev/a6a959d40d3d
>>> Satish
>>>> And we have our first petsc-maint breakage due to this Fortran 2003
>>> thingy.
>>>> On Thu, May 31, 2012 at 9:03 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> This code is using "use,intrinsic :: iso_c_binding"
>>>>> Isn't this a fortran 2003 thingy? Perhaps there should be a configure
>>>>> checks for it.
>>>>> Satish
>>>>> On Wed, 30 May 2012, Barry Smith wrote:
>>>>>>   Blaise,
>>>>>>    I have pushed PetscOptionsGetEnum() and PetscBagRegisterEnum()
>>> for
>>>>> f90 to petsc-dev tests are in src/sys/examples/tutorials
>>>>>>   Barry
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
