[petsc-dev] What needs to be done before a release?
Thu May 31 11:53:04 CDT 2012
So how do we deal with this function not being implemented unless an F2003
compiler is used? Just #ifdef its body and produce a run-time error when an
old compiler is used? Satish, are you doing this?
On Thu, May 31, 2012 at 11:36 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Added configure check.
> http://petsc.cs.iit.edu/petsc/releases/BuildSystem-3.3/rev/a6a959d40d3d
> Satish
> On Thu, 31 May 2012, Jed Brown wrote:
> > And we have our first petsc-maint breakage due to this Fortran 2003
> thingy.
> > On Thu, May 31, 2012 at 9:03 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > This code is using "use,intrinsic :: iso_c_binding"
> > > Isn't this a fortran 2003 thingy? Perhaps there should be a configure
> > > checks for it.
> > > Satish
> > > On Wed, 30 May 2012, Barry Smith wrote:
> > > >    Blaise,
> > > >     I have pushed PetscOptionsGetEnum() and PetscBagRegisterEnum()
> for
> > > f90 to petsc-dev tests are in src/sys/examples/tutorials
> > > >    Barry
> > > > On May 29, 2012, at 3:29 AM, Blaise Bourdin wrote:
> > > > > On May 29, 2012, at 1:18 AM, Barry Smith wrote:
> > > > >> Blaise,
> > > > >>    How about the attached? My goal is to have the usage be as
> similar
> > > to the other PetscOptions... calls and too not require the Fortran
> user to
> > > be C aware that is, they should not have to append null characters or
> > > declare special C type declaration. In other words, the user writes
> > > Fortran77 code :-).[see attached file: ex1f.F90]
> > > > >>    I don't think it should bleed, but then I am no longer a
> Fortran
> > > programmer.
> > > > > Once a fortran programmer, always a fortran programmer... It's not
> > > like there is a lot to forget.
> > > > > Now I understand what you want. I agree with your goal of making
> the
> > > call standard and transparent. There is one issue with this approach
> for a
> > > function like PetscBagRegisterEnum (as far as I understand the C code),
> > > where you don't copy the string array in the bag item structure, but
> keep a
> > > reference to it (l. 80 in bag.c). After Carray and list1 are
> deallocated,
> > > the bag item->list points to some nonsense. I lost my mind trying to
> find a
> > > workaround last week.
> > > > > Would you be OK with requesting that each of the strings in list
> have
> > > some padding at the end, and be modified in the wrapper (adding the
> > > C_NULL_CHAR)? The alternative would be to modify PetscBagRegisterEnum,
> in
> > > order to store the content of list instead of just a reference, which
> may
> > > not be something you want to do right now.
> > > > > Blaise
> > > > >>   Barry
> > > > >> On May 27, 2012, at 10:16 AM, Blaise Bourdin wrote:
> > > > >>> Barry,
> > > > >>> If I frame your email, will you sign it for me? ;)
> > > > >>> I am traveling so I did not have much time to do it, even in my
> > > sleep, but Tim's solution is essentially right.
> > > > >>> Have a look at the attached code. I had to write my own
> interface to
> > > PetscOptionsGetEnum, but I have to do the equivalent of FIXCHAR by
> myself
> > > (basically appending  //C_NULL_CHAR). I checked in the debugger, and
> the
> > > list argument that is passed to PetscOptionsGetEList is the same as
> the one
> > > passed from C. Is this what you want?
> > > > >>> Do you want to do the FIXCHAR business in the C or fortran side?
> I
> > > suspect that you would prefer not having to append the C_NULL_CHAR in
> > > fortran, but I can't figure how to do that without allocating a new
> array
> > > of strings, and causing a memory leak. What do you think?
> > > > >>> If this is not what you want, could you meet me half way and
> write
> > > the fortran interface you would like to use, in which case I will try
> to
> > > write the missing fortran parts.
> > > > >>> Blaise
> > > > >>> <PetscF2003.F90>
> > > > >>>> Tim,
> > > > >>>> Thanks. But what I want is all bundled up a routine that takes
> in
> > > the Fortran array of character strings and allocates and copies over
> them
> > > to the C ptr business. Likely I could figure it out myself with but
> Blaise
> > > is such a Fortran wizard he can do it optimally in his sleep :-)
> > > > >>>> Barry
> > > > >>>> On May 25, 2012, at 8:14 PM, Tim Gallagher wrote:
> > > > >>>>> For what it's worth, I answered a question about how to pass
> > > string arrays awhile ago on StackOverflow:
> http://stackoverflow.com/questions/9686532/arrays-of-strings-in-fortran-c-bridges-using-iso-c-binding/9686741#9686741
> > > > >>>>> Tim
> > > > >>>>> ----- Original Message -----
> > > > >>>>> From: "Barry Smith" <bsmith at mcs.anl.gov>
> > > > >>>>> To: "For users of the development version of PETSc" <
> > > petsc-dev at mcs.anl.gov>
> > > > >>>>> Sent: Friday, May 25, 2012 8:57:52 PM
> > > > >>>>> Subject: Re: [petsc-dev] What needs to be done before a
> release?
> > > > >>>>> Blaise
> > > > >>>>> If you provide a fortran function to convert an array of
> Fortran
> > > strings to an array of C strings and tell us how to delete the result
> then
> > > we'll provide a PetscOptionsGetEnum() for Fortran.
> > > > >>>>> Barry
> > > > >>>>> On May 2, 2012, at 12:02 PM, Blaise Bourdin wrote:
> > > > >>>>>> Barry,
> > > > >>>>>>>> Also, fortran wrappers over PetscOptionsEnum and
> > > PetscBagRegisterEnum would be nice. I understand that it
> > > > >>>>>>>> is a bit tricky since it involves passing fortran arrays of
> > > strings.
> > > > >>>>>>> Yup. We'd be willing to support these from FORTRAN but
> someone
> > > else has to do the dirty work of figuring out how to handle those
> array of
> > > strings (maybe F2003?).
> > > > >>>>>> I am attaching a simple proof of concept example that
> > > demonstrates how to write a fortran interface and call petsc C
> functions
> > > from fortran using F2003 C-interoperability instead of going through
> the
> > > fortran bindings.
> > > > >>>>>> Don't be put off by all the warnings if you use gfortran. They
> > > would be easy to avoid. Basically, right now, you detect the fortran
> > > integer and real kinds that match that of the C ones. It would be quite
> > > simple to get the fortran C-interoperable integer and real types
> associated
> > > with the C type of PetscInt, PetscReal etc.
> > > > >>>>>> Basically, we (I?) could write a fortran interface and a
> fortran
> > > function for the tricky functions involving arrays of string, instead
> of
> > > creating a custom binding in C. Are you willing to let some fortran
> > > pollution into the petsc code? Where would these function have to be?
> > > > >>>>>> Blaise
> > > > >>>>>> PS: you need FCFLAGS='-ffixed-line-length-none
> > >  -ffree-line-length-none -ffree-form' or some subset of these to
> compile
> > > with gfortran. I'm not sure why these are not the default with a file
> > > suffix .F90
> > > > >>>>>> <PetscF2003Binding.F90>
> > > > >>>>>> Department of Mathematics and Center for Computation &
> Technology
> > > > >>>>>> Louisiana State University, Baton Rouge, LA 70803, USA
> > > > >>>>>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> > > http://www.math.lsu.edu/~bourdin
> > > > >>> Department of Mathematics and Center for Computation & Technology
> > > > >> <ex1f.F90>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120531/5d23bdbf/attachment.html>
