[petsc-dev] release preparation
Dave Nystrom dnystrom1 at comcast.net
Thu May 31 09:02:42 CDT 2012
Thanks.  Good to know.
Dave
Satish Balay writes:
 > balay at petsc:/sandbox/balay/petsc-dev $ hg tags
 > tip                            23486:c76fb3cac2a4
 > release-3.2                    20307:cad0859b4453
 > release-3.1                    15532:f6965e7f147c
 > release-3.0.0                  13216:621178841b37
 > release-2.3.3                  10547:c59a3fc37afc
 > release-2.3.2                   9364:1aa4d6336f27
 > When we do the release - we do add a tag for it [in the release repo -
 > that propegates to petsc-dev]. But the release is not done yet.
 > However we haven't been adding tags for patch updates.
 > Satish
 > On Thu, 31 May 2012, Dave Nystrom wrote:
 > > Is there a tag that reflects the petsc-dev state at release time?
 > > Thanks,
 > > Dave
 > >  > I've now created the release repos - so petsc-dev is now open for all
 > >  > commits.
 > >  > [If you've accumulated petsc-dev related commits - rebasing them with
 > >  > current petsc-dev - before pushing would be good.]
 > >  > Release related commits should now go to the release repo [and not
 > >  > directly to petsc-dev]. Please use the usual release repo
 > >  > workflow. i.e:
 > >  > - clone the release repos
 > >  > - commit/push [to release-repos]
 > >  > - from petsc-dev clone - pull/merge release commits and push to petsc-dev.
 > >  > [or defer this last step to me until the release]
 > >  > ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.3
 > >  > ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/BuildSystem-3.3
 > >  > Satish
 > >  > On Thu, 17 May 2012, Barry Smith wrote:
 > >  > >   petsc-dev folks,
 > >  > >     Recall that we are in a phase of a code freeze that means do not push random new code to petsc-dev, push only bug fixes and clean up to petsc-dev.  By all means keep on with code development, just don't push the new stuff to petsc-dev.
 > >  > >      We hope to make the release repository (and then tarball) next Wednesday May 23. So please do be checking the nightly builds and making fixes to petsc-dev.
 > >  > >    Barry
 > >  > > Note: threaded code and GPU code will not be supported with the release (users should continue to use petsc-dev after the release) so fixes/extensions to those things are not needed and shouldn't be pushed to petsc-dev at the moment.
