[petsc-dev] Multigrid is confusing
Jed Brown five9a2 at gmail.com
Fri May 25 08:33:47 CDT 2012
Fair point for large subdomains, but two additive have two comm steps
instead of one.
On May 25, 2012 8:24 AM, "Mark F. Adams" <mark.adams at columbia.edu> wrote:
> On May 25, 2012, at 8:59 AM, Jed Brown wrote:
> On Fri, May 25, 2012 at 1:07 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>> And, I've never seen Gauss-Siedel used with Cheby because G-S has the
>> correct damping properties, as is, for the Laplacian.
> The point is to have something adequate for things that are not
> Laplacians. I tried running SOR without Cheby, but it was far less robust.
> So I know it looks funny, but I don't have a similarly robust alternative.
> If we are living in a world where local work is cheap, we might as well do
> local SOR instead of pbjacobi. (Note that Cheby+pbjacobi is nearly as good
> as Cheby+SOR in some cases, but much worse in others.)
>> Note, G-S is not symmetric and Cheby for unsymmetric is a different can
>> of worms.  So if A is symmetric then maybe try SSOR.
> The default SOR is local_symmetric.
> So it does a forward and backward pass.  So it is really two smoothing
> steps.  One should compare it with two additive smoothers.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120525/70e3359d/attachment.html>
