[petsc-dev] Need a CFLAGS that does is *not* included in the link
Thu May 24 21:33:49 CDT 2012
On Thu, May 24, 2012 at 9:31 PM, Chetan Jhurani <chetan.jhurani at gmail.com>wrote:
> I faced a similar problem when using -x argument with nvcc during****
> petsc configuration, which could be fixed if CFLAGS was not passed****
> to the linker. So sending this info in case it is useful.
So in general, CFLAGS must be passed to the linker (it contains
optimization and debugging stuff that should be consistent). The -x option
is very special in that it cannot be passed to the linker.
> [jhurani at enrico ~]$ cat a.c****
> int main()****
> [jhurani at enrico ~]$ nvcc a.c -x c++ -c****
> [jhurani at enrico ~]$ nvcc a.o -x c++****
> a.o:1: error: stray '\177' in program****
> a.o:1: error: stray '\2' in program****
> a.o:1: error: stray '\1' in program****
> a.o:1:8: warning: null character(s) ignored****
> a.o:1:18: warning: null character(s) ignored****
> and many more lines…****
> Chetan****
> *From:* petsc-dev-bounces at mcs.anl.gov [mailto:
> petsc-dev-bounces at mcs.anl.gov] *On Behalf Of *Jed Brown
> *Sent:* Thursday, May 24, 2012 7:09 PM
> *To:* For users of the development version of PETSc
> *Subject:* [petsc-dev] Need a CFLAGS that does is *not* included in the
> link****
> Building PETSc with clang++ produces a warning about compiling *.c as C++
> being deprecated. To silence the warning, we would need to pass "-x c++" to
> the compiler, but NOT to the linker. CFLAGS is currently also passed to the
> linker. Is this something we want to fix?****
> Clang used to SEGV when "-x c++" is passed to the linker. Now (latest SVN)
> it just interprets the object file as C++ source (which obviously produces
> a ton of garbage).****
> http://llvm.org/bugs/show_bug.cgi?id=12924****
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120524/006421ef/attachment.html>
