[petsc-dev] Multigrid is confusing
Wed May 23 14:52:18 CDT 2012
On Wed, May 23, 2012 at 2:26 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  This looks good:
> $ $base -mg_levels_ksp_type chebyshev
> -mg_levels_ksp_chebyshev_estimate_eigenvalues 0.1,1.1 -mg_levels_ksp_max_it
> 2 -mg_levels_pc_type sor
> lid velocity = 100, prandtl # = 1, grashof # = 10000
>  Linear solve converged due to CONVERGED_RTOL iterations 10
>  Linear solve converged due to CONVERGED_RTOL iterations 7
>  Linear solve converged due to CONVERGED_RTOL iterations 8
>  Linear solve converged due to CONVERGED_RTOL iterations 9
> Number of SNES iterations = 9
>    I assume it is independent of the number of levels of refinement?
$ $base -da_refine 0 -snes_grid_sequence 5 -mg_levels_ksp_type chebyshev
            Linear solve converged due to CONVERGED_RTOL iterations 13
            Linear solve converged due to CONVERGED_RTOL iterations 12
            Linear solve converged due to CONVERGED_RTOL iterations 11
        Linear solve converged due to CONVERGED_RTOL iterations 14
    Linear solve converged due to CONVERGED_RTOL iterations 6
  Linear solve converged due to CONVERGED_RTOL iterations 5
Number of SNES iterations = 4
>  Note that you could use -pc_type eisenstat perhaps in this case instead.
> Might save lots of flops?  I've often wondered about doing Mark's favorite
> chebyshev smoother with Eisenstat, seems like it should be a good match.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: Cannot have different mat and pmat!
>   Barry
> On May 23, 2012, at 11:48 AM, Jed Brown wrote:
> > If ex19 is what matters...
> > $ base='mpiexec.hydra -n 4 ./ex19 -da_refine 3 -lidvelocity 100 -grashof
> 1e4 -pc_type mg -ksp_type fgmres -pc_mg_type full -ksp_converged_reason'
> > $ $base
> >   Linear solve converged due to CONVERGED_RTOL iterations 23
> >   Linear solve converged due to CONVERGED_RTOL iterations 17
> >   Linear solve converged due to CONVERGED_RTOL iterations 15
> >   Linear solve converged due to CONVERGED_RTOL iterations 19
> >   Linear solve converged due to CONVERGED_RTOL iterations 21
> >   Linear solve converged due to CONVERGED_RTOL iterations 18
> 1 -mg_levels_pc_type pbjacobi
> >   Linear solve converged due to CONVERGED_RTOL iterations 25
> >   Linear solve converged due to CONVERGED_RTOL iterations 27
> >   Linear solve converged due to CONVERGED_RTOL iterations 30
> >   Linear solve converged due to CONVERGED_RTOL iterations 28
> >   Linear solve converged due to CONVERGED_RTOL iterations 42
> >   Linear solve converged due to CONVERGED_RTOL iterations 49
> >   Linear solve converged due to CONVERGED_RTOL iterations 52
> >   Linear solve converged due to CONVERGED_RTOL iterations 48
> 1 -mg_levels_pc_type sor
> >   Linear solve converged due to CONVERGED_RTOL iterations 22
> >   Linear solve converged due to CONVERGED_RTOL iterations 16
> >   Linear solve converged due to CONVERGED_RTOL iterations 20
> 2 -mg_levels_pc_type pbjacobi
> 3 -mg_levels_pc_type pbjacobi
> 3 -mg_levels_pc_type sor
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120523/18360d7d/attachment.html>
