[petsc-dev] cheby.c
Hong Zhang hzhang at mcs.anl.gov
Tue May 22 16:17:06 CDT 2012
Barry,
Do you recall the paper or detailed Chebyshev algorithm that you
implemented the Chebyshev in petsc?
I added 'hybrid' to it, which is not correct. Jie is helping to fix it.
Having an original
algorithm would help.
On Tue, May 22, 2012 at 1:21 PM, Jie Chen <jiechen at mcs.anl.gov> wrote:
>> Then do you know who wrote the code? Hong said it was you.
> It was written in the 90s, before version control history.
Sorry, my mistake. I recall that Barry said that he wrote it when Jed was
in dia... ;-(
Hong
>> Hong is trying to modify the code but there is something wrong. I am
>> helping to see what is the problem. The code itself is fine.
> Hard to speculate without more than "something wrong".
>> Jie
>> ----- Original Message -----
>> From: "Jed Brown" <jedbrown at mcs.anl.gov>
>> To: "Jie Chen" <jiechen at mcs.anl.gov>, "For users of the development
>> version of PETSc" <petsc-dev at mcs.anl.gov>
>> Sent: Tuesday, May 22, 2012 1:18:07 PM
>> Subject: Re: cheby.c
>> On Tue, May 22, 2012 at 12:37 PM, Jie Chen < jiechen at mcs.anl.gov > wrote:
>> Jed, I am reading your implementation of the chebyshev code. The
>> algorithm does not seem to be the same as the version I am familiar with.
>> Did you implement it according to some paper or book?
>> I didn't write it.
>> What do you find strange?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120522/af2f5506/attachment.html>
