[petsc-dev] anyone feel like fixing a bug?
Mark F. Adams mark.adams at columbia.edu
Sat May 19 10:57:29 CDT 2012
I'm going to be tied up for a few days, should be able to get to this Wed., if not sooner, but if anyone wants to take a crack at it, here it is. This is run with 8 procs.
==51037== Command: ./ex56 -ne 19 -alpha 1.e-3 -ksp_type cg -ksp_monitor -ksp_max_it 15 -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -pc_gamg_verbose 2 -ksp_converged_reason -options_left -theta -30.0 -epsilon .01 -blob_center 0.,0. -pc_gamg_threshold .0 -pc_gamg_coarse_eq_limit 100 -use_coordinates -out_verbose 2 -aggmg_smooths 1 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.2,0,1.1 -mg_levels_pc_type pbjacobi -mg_levels_ksp_max_it 1
==51039== Invalid read of size 8
==51039==    at 0x91E38B: PCApply_PBJacobi_3 (pbjacobi.c:81)
==51039==    by 0xA0FE23: PCApply (precon.c:384)
==51039==    by 0xADA9B2: KSPInitialResidual (itres.c:64)
==51039==    by 0xA7EA39: KSPSolve_GMRES (gmres.c:230)
==51039==    by 0xAB3CA2: KSPSolve (itfunc.c:446)
==51039==    by 0xAA6FF8: KSPSolve_Chebyshev (cheby.c:269)
==51039==    by 0x9ECD2F: PCMGMCycle_Private (mg.c:20)
==51039==    by 0x9F0BEF: PCApply_MG (mg.c:321)
==51039==    by 0xA43EBF: KSPSolve_CG (cg.c:139)
==51039==    by 0x4805: main (in ./ex56)
==51039==  Address 0x27f4c90 is 0 bytes after a block of size 24,032 alloc'd
==51039==    at 0x1B2AF16: malloc (vg_replace_malloc.c:236)
==51039==    by 0x8A8C7: PetscMallocAlign (mal.c:37)
==51039==    by 0x61E602: MatInvertBlockDiagonal_SeqAIJ (aij.c:2816)
==51039==    by 0x2F0AC3: MatInvertBlockDiagonal (matrix.c:9280)
==51039==    by 0x6D1494: MatInvertBlockDiagonal_MPIAIJ (mpiaij.c:2981)
==51039==    by 0x920A85: PCSetUp_PBJacobi (pbjacobi.c:213)
==51039==    by 0xA1783B: PCSetUp (precon.c:832)
==51039==    by 0xAB2125: KSPSetUp (itfunc.c:278)
==51039==    by 0x9F536C: PCSetUp_MG (mg.c:678)
==51039==    by 0x98C26C: PCSetUp_GAMG (gamg.c:984)
==51039==    by 0x46AD: main (in ./ex56)
==51039==
