[petsc-dev] patch for block size in VecLoad_HDF5
Blaise Bourdin bourdin at lsu.edu
Wed May 16 17:27:47 CDT 2012
ex19 in src/vec/vec/examples/tutorials is still broken, since changing block size of a Vec is no longer supported.
the mechanism in VecLoad_HDF5 was to rely on an undocumented flag (-vecload_block_size)
Shall we require that the block size be set _before_ calling VecLoad (in which case, I will push a patch to VecLoad_HDF5), or should the block size be obtained from the hdf5 files and set?
Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
