[petsc-dev] fortran questions
Wed May 16 11:48:38 CDT 2012
On Wed, 16 May 2012, Satish Balay wrote:
> On Wed, 16 May 2012, Blaise Bourdin wrote:
> > Hi,
> > I am trying to have a look at the fortran modules code.
> > - the petsc and petscdef modules are defined in src/ts/f90-mod/petsctsmod.F would it make more sense to move them to src/f90-mod/petscmod.F
> The progression was as follows:
> - every petsc object [in the object hierarchy] has its own module -
>   i.e petscts is in src/ts/f90-mod/petsctsmod.F
> - and each module shoud be built in the correct order of
>   hierarchy. [i.e 'petscts' is built after 'petscsnes']
> - we decided to have 'petsc' and 'petscdef' to be the over-arching
>   module for all petsc modules - hence they are in
>   src/ts/f90-mod/petsctsmod.F.
> So src/f90-mod/petscmod.F is an appropriate place for 'petscsys.mod'
> but not 'petsc.mod'. If we have to move it out of ts - then it would
> probably be some new dir like:
> src/overarching-super-petsc/f90-mod/petsctsmod.F or some more suitable
> name.
sorry - I misread 'src/f90-mod/petscmod.F' as 'src/sys/f90-mod/petscmod.F'
So - yes - perhaps thats a suitable location.
Satish
> > - Is there a valid reason for not including petscdef.h in the module petsc?
> Hm - because its a supermodule that makes sure all petsc component
> modules are getting used? So each component module already had the
> necessary stuff? BTW: the def.h files [like petscdef.h] just have
> preprocessing info - so it doesn't get instantiated into the
> module. [All of this #define stuff needs to be transformed into a
> format that can be instantiated in a module eventually]
> > - I would like to create the fortran datatype for PetscBag (Barry: yes, I have a fortran fetish), but I am not completely sure where to start. In particular, how are the .h / .h90 in include/finclude/f90-auto created?
> bfort should be creating these during fortranstub generation [either
> during configure step - or with 'make allfortranstubs']. If the c-code
> has a formatted comment that tells bfort to auto-generate fortran stub
> - it might also generate the 'interface' function and stash it in
> include/finclude/f90-auto.
> Satish
