[petsc-dev] ex43_3 stokes problem FAIL
Tue May 15 14:53:37 CDT 2012
   Mark,
   I commented out the MatSetBlockSize() calls  in the MatGetSubMatrices() this is why it no longer crashes. But, of course, you will never get the blocksize you want out of it. You need to set the block size conditionally based on the "right" IS being passed in.
   Barry
On May 15, 2012, at 2:48 PM, Mark F. Adams wrote:
> I do not seem to be able to reproduce these errors. This is what I see:
> ~/Codes/petsc-dev/src/ksp/ksp/examples/tutorials>make runex49
> 30c30
> <  28 KSP Residual norm 0.000350713
>> 28 KSP Residual norm 0.000350714
> 41c41
> <  39 KSP Residual norm 9.38531e-05
>> 39 KSP Residual norm 9.38532e-05
> 43c43
> <  41 KSP Residual norm 5.55156e-05
>> 41 KSP Residual norm 5.55157e-05
> /Users/markadams/Codes/petsc-dev/src/ksp/ksp/examples/tutorials
> Possible problem with with ex49_1, diffs above
> ~/Codes/petsc-dev/src/ksp/ksp/examples/tutorials>make runex49_3
> ~/Codes/petsc-dev/src/ksp/ksp/examples/tutorials>make runex49_2
> Mark
> On May 11, 2012, at 10:34 PM, Barry Smith wrote:
>> Same problem with ex49, what the fuck are you guys thinking?
>> [2]PETSC ERROR: --------------------- Error Message ------------------------------------
>>> [2]PETSC ERROR: Arguments are incompatible!
>>> [2]PETSC ERROR: Local size 315 not compatible with block size 2!
>>> [2]PETSC ERROR: ------------------------------------------------------------------------
>>> [2]PETSC ERROR: Petsc Development HG revision: 5df5da2fbee0018d6214063ab12ea49c0847b4f8  HG Date: Fri May 11 13:26:59 2012 -0500
>>> [2]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [2]PETSC ERROR: See docs/index.html for manual pages.
>>> [2]PETSC ERROR: ./ex49 on a arch-gnu named barry-smiths-macbook-pro.local by barrysmith Fri May 11 18:47:27 2012
>>> [2]PETSC ERROR: Libraries linked from /Users/barrysmith/Src/petsc-dev/arch-gnu/lib
>>> [2]PETSC ERROR: Configure run at Fri May 11 18:30:02 2012
>>> [2]PETSC ERROR: Configure options --download-blacs --download-fftw --download-hypre --download-libyaml --download-metis --download-ml --download-mpich --download-mumps --download-parmetis --download-ptscotch --download-scalapack --download-superlu --download-superlu_dist --download-yaml --with-ams-dir=/Users/barrysmith/Src/ams-dev --with-java --with-openmp --with-server --with-shared-libraries PETSC_ARCH=arch-gnu
>>> [2]PETSC ERROR: PetscLayoutSetBlockSize() line 459 in /Users/barrysmith/Src/petsc-dev/src/vec/vec/impls/mpi/pmap.c
>>> [2]PETSC ERROR: MatSetBlockSizes() line 6843 in /Users/barrysmith/Src/petsc-dev/src/mat/interface/matrix.c
>>> [2]PETSC ERROR: MatGetSubMatrices_MPIAIJ_Local() line 1312 in /Users/barrysmith/Src/petsc-dev/src/mat/impls/aij/mpi/mpiov.c
>>> [2]PETSC ERROR: MatGetSubMatrices_MPIAIJ() line 786 in /Users/barrysmith/Src/petsc-dev/src/mat/impls/aij/mpi/mpiov.c
>>> [2]PETSC ERROR: MatGetSubMatrices() line 6498 in /Users/barrysmith/Src/petsc-dev/src/mat/interface/matrix.c
>>> [2]PETSC ERROR: MatGetSubMatrix_MPIAIJ_Private() line 3554 in /Users/barrysmith/Src/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
>>> [2]PETSC ERROR: MatGetSubMatrix_MPIAIJ() line 3515 in /Users/barrysmith/Src/petsc-dev/src/mat/impls/aij/mpi/mpiaij.c
>>> [2]PETSC ERROR: MatGetSubMatrix() line 7344 in /Users/barrysmith/Src/petsc-dev/src/mat/interface/matrix.c
>>> [2]PETSC ERROR: DMDABCApplySymmetricCompression() line 1348 in src/ksp/ksp/examples/tutorials/ex49.c
>>> [2]PETSC ERROR: solve_elasticity_2d() line 1080 in src/ksp/ksp/examples/tutorials/ex49.c
>>> [2]PETSC ERROR: main() line 1138 in src/ksp/ksp/examples/tutorials/ex49.c
>>> application called MPI_Abort(MPI_COMM_WORLD, 75) - process 2
>>> [cli_2]: aborting job:
>> On May 11, 2012, at 9:31 PM, Barry Smith wrote:
>>> Please run make alltests before pushing changes!
>>> Who ever pushed this broken code please fix.
>>> runex43_3:
>>> 	-@${MPIEXEC} -n 4 ./ex43 -stokes_ksp_type gcr -stokes_ksp_gcr_restart 60 -stokes_ksp_norm_type unpreconditioned -stokes_ksp_rtol 1e-8 -c_str 3 -sinker_eta0 1.0 -sinker_eta1 100 -sinker_dx 0.4 -sinker_dy 0.3 -mx 128 -my 128 -stokes_ksp_monitor_short -stokes_pc_type mg -stokes_mg_levels_pc_type fieldsplit -stokes_pc_mg_galerkin -stokes_mg_levels_pc_fieldsplit_block_size 3 -stokes_mg_levels_pc_fieldsplit_0_fields 0,1 -stokes_mg_levels_pc_fieldsplit_1_fields 2 -stokes_mg_levels_fieldsplit_0_pc_type sor -stokes_mg_levels_fieldsplit_1_pc_type sor -stokes_mg_levels_ksp_type chebyshev -stokes_mg_levels_ksp_max_it 1 -stokes_mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.2,0,1.1 -stokes_pc_mg_levels 4 -stokes_ksp_view > ex43_3.tmp 2>&1;	  \
>>> 	   ${DIFF} output/ex43_3.out ex43_3.tmp || echo ${PWD} "\nPossible problem with with ex43_3, diffs above \n========================================="; \
>>> 	   ${RM} -f ex43_3.tmp
>>>> [2]PETSC ERROR: Local size 8320 not compatible with block size 3!
>>>> [2]PETSC ERROR: ./ex43 on a arch-gnu named barry-smiths-macbook-pro.local by barrysmith Fri May 11 21:28:34 2012
>>>> [2]PETSC ERROR: PCSetUp_FieldSplit() line 445 in /Users/barrysmith/Src/petsc-dev/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>> [2]PETSC ERROR: PCSetUp() line 832 in /Users/barrysmith/Src/petsc-dev/src/ksp/pc/interface/precon.c
>>>> [2]PETSC ERROR: KSPSetUp() line 278 in /Users/barrysmith/Src/petsc-dev/src/ksp/ksp/interface/itfunc.c
>>>> [2]PETSC ERROR: PCSetUp_MG() line 678 in /Users/barrysmith/Src/petsc-dev/src/ksp/pc/impls/mg/mg.c
>>>> [2]PETSC ERROR: KSPSolve() line 402 in /Users/barrysmith/Src/petsc-dev/src/ksp/ksp/interface/itfunc.c
>>>> [2]PETSC ERROR: solve_stokes_2d_coupled() line 1502 in src/ksp/ksp/examples/tutorials/ex43.c
>>>> [2]PETSC ERROR: main() line 1621 in src/ksp/ksp/examples/tutorials/ex43.c
>>> /Users/barrysmith/Src/petsc-dev/src/ksp/ksp/examples/tutorials
