[petsc-dev] API changes in MatIS
Stefano Zampini stefano.zampini at gmail.com
Fri May 11 18:11:46 CDT 2012
2012/5/11 Jed Brown <jedbrown at mcs.anl.gov>
> Isn't PtAP still the right operation, you just have a particular
> implementation that takes advantage of structure?
yes it is, but since it is an expensive operations (P is dense), in BDDC,
once you solved the local problems to create P, you have almost straigthly
(and at a very low cost) the columns of the coarse matrix. The latter can
be obtained (as it is implemented in the code) as C^T\Lambda where C is the
local sparse  matrix of constraints, and \Lambda is a dense and small
matrix of lagrange multipliers.
> I know you can also assemble B A^{-1} B^T, which is the same thing, and
> maybe we should provide a generic op for that.
What is B? the jump operator?
> On May 11, 2012 1:17 PM, "Stefano Zampini" <stefano.zampini at gmail.com>
>>> I don't like this idea of the matrix type determining the algorithm, I'd
>>> rather choose the algorithm.
>> This is note the case in my BDDC: it is the algorithm that drives the
>> type of matrix to be built.
>>> Can we decouple it by building the prolongation operator P whose columns
>>> are harmonic extension of the coarse nodes? Then the coarse operator looks
>>> like P^T A P just like multigrid (for which we have a matop) instead of
>>> looking like a Schur complement.
>> I already have it. Each process has its local part, splitted in the
>> matrices pcbddc->coarse_phi_B (local interface nodes) and  (optionally)
>> pcbddc->coarse_phi_D (local dirichlet nodes). You can see that I used them
>> to check the correctness of the coarse local part in the code (see line
>> 1702 of bddc.c). I build the local part of coarse matrix , but I don't use
>> the expensive PtAP operation. Instead, I evaluate it by exploiting
>> properties of the saddle point problem they come from.
>>>  On May 10, 2012 2:42 PM, "Stefano Zampini" <stefano.zampini at gmail.com>
>>> wrote:
>>>> This is to do recursive BDDC or what?
>>>> Yes. When creating the BDDC coarse matrix, now the code has three 3
>>>> options
>>>> A) coarse matrix is a MATIS -> multilevel BDDC
>>>> B) coarse matrix is SEQAIJ -> one level BDDC with only one proc (or
>>>> all) solving directly the coarse problem
>>>> C) coarse matrix is MPIAIJ -> one level  BDDC with a parallel direct
>>>> solve
>>>> I think that PCREDUNDANT can do the job in both cases of options B if
>>>> the matrix would be parallel.
>> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120512/c6d72b68/attachment.html>
