[petsc-dev] Error during KSPDestroy
Mon May 7 11:18:56 CDT 2012
On Mon, May 7, 2012 at 11:53 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 7 May 2012, Barry Smith wrote:
> >    I am also running complex.
> >     Look in the file dlasq2.f (it will be in the externalpackages
> subdirectory of the PETSc directory. Look at line 215, this is where
> valgrind has a problem. In my copy
> >       END IF
> > *     Check for negative data and compute sums of q's and e's.
>                                                     <------ this is line 215
> >       Z( 2*N ) = ZERO
> > it is a comment, which is not good. Is lione 215 also a comment in your
> copy of dlasq2.f?
> > There are two possible causes I can think of for your problem
> > 1) PETSc does not allocate enough work space for zgesvd() or
> > 2) the BLAS/LAPACK routines have a bug where they sometimes access out
> of their work space.
> >    Satish,
> >      Can you try the same build options on a Linux machine as close to
> Alexander as we have and see if you can reproduce this?
> I can reproduce on my linux laptop. [also on petsc.mcs]
Are we forgetting the factor 2 on the workspace?
   Matt
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120507/7720d028/attachment.html>
