[petsc-dev] Error during KSPDestroy
Alexander Grayver agrayver at gfz-potsdam.de
Mon May 7 09:10:50 CDT 2012
On 07.05.2012 15:04, Barry Smith wrote:
>     I am also running complex.
>      Look in the file dlasq2.f (it will be in the externalpackages subdirectory of the PETSc directory. Look at line 215, this is where valgrind has a problem. In my copy
>        END IF
> *     Check for negative data and compute sums of q's and e's.
> *<------ this is line 215
>        Z( 2*N ) = ZERO
> it is a comment, which is not good. Is lione 215 also a comment in your copy of dlasq2.f?
Barry,
*     Rearrange data for locality: Z=(q1,qq1,e1,ee1,q2,qq2,e2,ee2,...).
       DO 30 K = 2*N, 2, -2
          Z( 2*K ) = ZERO                                             !
<----------- LINE 215
          Z( 2*K-1 ) = Z( K )
          Z( 2*K-2 ) = ZERO
          Z( 2*K-3 ) = Z( K-1 )
    30 CONTINUE
In valgrind log you can see that it complaints about following lines as
well:
==9009== Invalid write of size 8
==9009==    at 0x10651D5: dlasq2_ (dlasq2.f:215)
==9009==    by 0x1064683: dlasq1_ (dlasq1.f:135)
==9009==    by 0x104EB3F: zbdsqr_ (zbdsqr.f:225)
==9009==    by 0x1023B74: zgesvd_ (zgesvd.f:2040)
==9009==    by 0xD38725: KSPComputeExtremeSingularValues_GMRES (gmreig.c:46)
==9009==    by 0xCB3CC7: KSPComputeExtremeSingularValues (itfunc.c:47)
==9009==    by 0x406DF2: main (solveTest.c:47)
==9009==  Address 0x6ef5d88 is 8 bytes before a block of size 832 alloc'd
==9009==    at 0x4C2786E: memalign (vg_replace_malloc.c:581)
==9009==    by 0x47E3CB: PetscMallocAlign (mal.c:30)
==9009==    by 0xD2E286: KSPSetUp_GMRES (gmres.c:73)
==9009==    by 0xCB5464: KSPSetUp (itfunc.c:239)
==9009==    by 0xCB6E56: KSPSolve (itfunc.c:402)
==9009==    by 0x406DDB: main (solveTest.c:46)
==9009==
==9009==    at 0x1065204: dlasq2_ (dlasq2.f:216)
==9009==
==9009==    at 0x1065223: dlasq2_ (dlasq2.f:217)
==9009==
==9009==    at 0x1065255: dlasq2_ (dlasq2.f:218)
All further output is also related to the Z array.
Hard to believe this is a LAPACK problem... I tried 3 implementations
over 2 machines.
I have bad feeling it's my stupid mistake somewhere... :)
Just in case, I run ubuntu 11.1 and PETSc is configured like this with
default gcc compiler:
./configure --with-petsc-arch=mpich-gcc-complex-debug-c
--download-f-blas-lapack --with-precision=double
--with-scalar-type=complex --download-mpich
> There are two possible causes I can think of for your problem
> 1) PETSc does not allocate enough work space for zgesvd() or
> 2) the BLAS/LAPACK routines have a bug where they sometimes access out of their work space.
>     Satish,
>       Can you try the same build options on a Linux machine as close to Alexander as we have and see if you can reproduce this?
>     Barry
> On May 7, 2012, at 2:16 AM, Alexander Grayver wrote:
>> On 06.05.2012 22:24, Barry Smith wrote:
>>>    Alexander,
>>>       I cannot reproduce this on my mac with 3 different blas/lapack.
>> Barry,
>> I'm surprised. I ran it on my home PC with ubuntu and PETSc configured from scratch as following:
>> --download-mpich --with-fortran-interfaces=1 --download-scalapack --download-blacs --with-scalar-type=complex --download-blas-lapack --with-precision=double
>> And it's still there.
>> Please note that all my numbers are complex.
>>>       Could you please run the case below but with --download-f-blas-lapack   (you forgot the -f last time)? Send us the valgrind results. This will tell use the exact line number in dlasq3() that is triggering the bad read.
>> I did:
>> ./configure --with-petsc-arch=openmpi-intel-complex-debug-c --download-scalapack --download-blacs --download-f-blas-lapack --with-precision=double --with-scalar-type=complex
>> And then valgrind program. The first message from log:
>> ==27656== Invalid write of size 8
>> ==27656==    at 0x15A8E9E: dlasq2_ (dlasq2.f:215)
>> ==27656==    by 0x15A83A4: dlasq1_ (dlasq1.f:135)
>> ==27656==    by 0x158ACEC: zbdsqr_ (zbdsqr.f:225)
>> ==27656==    by 0x154EC27: zgesvd_ (zgesvd.f:2038)
>> ==27656==    by 0x695DD3: KSPComputeExtremeSingularValues_GMRES (gmreig.c:46)
>> ==27656==    by 0x69DD76: KSPComputeExtremeSingularValues (itfunc.c:47)
>> ==27656==    by 0x44E98C: main (solveTest.c:62)
>> ==27656==  Address 0xfad2d98 is 8 bytes before a block of size 832 alloc'd
>> ==27656==    at 0x4C25D66: memalign (vg_replace_malloc.c:694)
>> ==27656==    by 0x4B642B: PetscMallocAlign (mal.c:30)
>> ==27656==    by 0x687775: KSPSetUp_GMRES (gmres.c:73)
>> ==27656==    by 0x69FE4A: KSPSetUp (itfunc.c:239)
>> ==27656==    by 0x6A2058: KSPSolve (itfunc.c:402)
>> ==27656==    by 0x44E969: main (solveTest.c:61)
>> Please find full log attached.
>>>      Barry
>>> On May 6, 2012, at 9:16 AM, Alexander Grayver wrote:
>>>> On 06.05.2012 15:34, Matthew Knepley wrote:
>>>>> On Sun, May 6, 2012 at 9:24 AM, Alexander Grayver<agrayver at gfz-potsdam.de>   wrote:
>>>>> Hm, valgrind gives a lot of output like that (see full log in previous message):
>>>>> Can you run this with --download-f-blas-lapack? This sounds much more like an MKL bug.
>>>> I did:
>>>> --download-scalapack --download-blacs --download-blas-lapack --with-precision=double --with-scalar-type=complex
>>>> The error is still there. I checked "ldd solveTest", mkl is not used for sure. This is not an MKL problem I guess:
>>>> ==13600== Invalid read of size 8
>>>> ==13600==    at 0x58636AF: dlasq3_ (in /usr/local/lib/liblapack.so.3.2.2)
>>>> ==13600==    by 0x5862C84: dlasq2_ (in /usr/local/lib/liblapack.so.3.2.2)
>>>> ==13600==    by 0x5861F2C: dlasq1_ (in /usr/local/lib/liblapack.so.3.2.2)
>>>> ==13600==    by 0x571A479: zbdsqr_ (in /usr/local/lib/liblapack.so.3.2.2)
>>>> ==13600==    by 0x57466A7: zgesvd_ (in /usr/local/lib/liblapack.so.3.2.2)
>>>> ==13600==    by 0x694687: KSPComputeExtremeSingularValues_GMRES (gmreig.c:46)
>>>> ==13600==    by 0x69C62A: KSPComputeExtremeSingularValues (itfunc.c:47)
>>>> ==13600==    by 0x44E02C: main (solveTest.c:62)
>>>> ==13600==  Address 0x10826b90 is 16 bytes before a block of size 832 alloc'd
>>>> ==13600==    at 0x4C25D66: memalign (vg_replace_malloc.c:694)
>>>> ==13600==    by 0x4B5ACB: PetscMallocAlign (mal.c:30)
>>>> ==13600==    by 0x686181: KSPSetUp_GMRES (gmres.c:73)
>>>> ==13600==    by 0x69E6FE: KSPSetUp (itfunc.c:239)
>>>> ==13600==    by 0x6A090C: KSPSolve (itfunc.c:402)
>>>> ==13600==    by 0x44E009: main (solveTest.c:61)
>>>> The weird thing is that the it gives correct result, so zgesvd works fine.
>>>> And also running this program with 10 iterations in valgrind doesn't produce error. The low above is with 100 iterations.
>>>> Without valgrind the error is always there.
>>>> Regards,
>>>> Alexander
>> Regards,
>> Alexander
>> <valgrind.zip>
Alexander
