[petsc-dev] DM RefineLevel and CoarsenLevel
Sun May 6 22:09:03 CDT 2012
The associated ugly hackery is here. I'd welcome suggestions for a better
way to do this.
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/9943253a5ac2
On Sun, May 6, 2012 at 3:57 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Now the next round:
> For semi-coarsening, we used to have stuff like -da_refine_hierarchy_x
> 1,1,3 -da_refine_hierarchy_y 2,2,1 -da_refine_hierarchy_z 2,2,1. Two
> changes make this harder now:
> 1. You essentially got rid of DMRefineHierarchy (it's not called any
> more), so each call to DMRefine and DMCoarsen have to figure out where they
> are.
> 2. Since the coarse DMs are not reused by PCMG, but instead created again
> using DMCoarsen, we have to figure out how to reverse the refinement
> process so that the same coarse grids get reconstructed again.
> I added a DMRefineHook so that we can port data the other way and I
> modified DMCoarsen_DA and DMRefine_DA to not call DMDACreate{1,2,3}d
> because it eagerly calls DMSetFromOptions before we can set the
> refinement/coarsen level. Unless someone stops me, I'm also going to add
> coarsen_{x,y,z} fields to DM_DA because the refinement ratio may have
> nothing to do with the coarsening ratio.
> I have no idea how to expose semi-coarsening through a C API other than to
> hold the refinement/coarsening path arrays in each DM_DA so that
> refinement/coarsening steps can be retraced.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120506/47f9e6c7/attachment.html>
