[petsc-dev] Error during KSPDestroy
Sun May 6 12:49:35 CDT 2012
Alexander,
   No attached test program. (only valgrind log).
  Barry
On May 6, 2012, at 8:21 AM, Alexander Grayver wrote:
> On 06.05.2012 15:07, Matthew Knepley wrote:
>>> Hello,
>>> I use KSP and random rhs to compute largest singular value:
>>> 1) Is this the whole program? If not, this can be caused by memory corruption somewhere else. This is what I suspect.
>> Matt,
>> I can reproduce error using attached test programm and this matrix (7 mb):
>> http://dl.dropbox.com/u/60982984/A.dat
>> I run it fine with the latest petsc-dev:
>>   1.405802e+00
>> Can you valgrind it on your machine?
> I did:
> valgrind --tool=memcheck -q --num-callers=20 --log-file=valgrind.log.%p /solveTest -ksp_monitor_true_residual -log_summary -mat_type aij -ksp_rtol 1.0e-10 -malloc off
> The error is better constrained:
> ==20287== Invalid read of size 8
> ==20287==    at 0x7874B4C: opal_os_path (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-pal.so.0.0.0)
> ==20287==    by 0x75F2E27: orte_session_dir_finalize (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0)
> ==20287==    by 0x76012E8: orte_errmgr_base_error_abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0)
> ==20287==    by 0x73396E9: ompi_mpi_abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libmpi.so.0.0.2)
> ==20287==    by 0x734F36E: PMPI_Abort (in /opt/mpi/intel/openmpi-1.4.2/lib/libmpi.so.0.0.2)
> ==20287==    by 0x7499AB: PetscDefaultSignalHandler (signal.c:169)
> ==20287==    by 0x749267: PetscSignalHandler_Private (signal.c:53)
> ==20287==    by 0x924B9DF: ??? (in /lib64/libc-2.11.1.so)
> ==20287==    by 0x535D9E: VecDestroyVecs (vector.c:653)
> ==20287==    by 0x68B61D: KSPReset_GMRES (gmres.c:258)
> ==20287==    by 0x6A9D39: KSPReset (itfunc.c:733)
> ==20287==    by 0x6AA839: KSPDestroy (itfunc.c:780)
> ==20287==    by 0x4509F8: main (solveTest.c:66)
> ==20287==  Address 0xbde4860 is 0 bytes inside a block of size 2 alloc'd
> ==20287==    at 0x4C26B9B: malloc (vg_replace_malloc.c:263)
> ==20287==    by 0x92876DF: vasprintf (in /lib64/libc-2.11.1.so)
> ==20287==    by 0x9266C67: asprintf (in /lib64/libc-2.11.1.so)
> ==20287==    by 0x75F1701: orte_util_convert_vpid_to_string (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0)
> ==20287==    by 0x75F2D4A: orte_session_dir_finalize (in /opt/mpi/intel/openmpi-1.4.2/lib/libopen-rte.so.0.0.0)
> Full log is attached.
> Important.
> If I comment this line:
> KSPComputeExtremeSingularValues(ksp, &maxx, &minx);
> It works.
> Regards,
> Alexander
> <valgrind.zip>
