[petsc-dev] Error in make test
Shri abhyshr at mcs.anl.gov
Sat May 5 09:30:42 CDT 2012
I pushed some changes to fix these errors. Can you please pull and retry. ----- Original Message -----
> I had pulled some hours ago from
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/61898f35c333 and obtained
> the following error on make test
> [0]PETSC ERROR: PetscCommDuplicate() line 200 in
> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/objects/tagm.c
> [0]PETSC ERROR: PetscHeaderCreate_Private() line 51 in
> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/objects/inherit.c
> [0]PETSC ERROR: SNESCreate() line 1293 in
> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/snes/interface/snes.c
> [0]PETSC ERROR: main() line 102 in src/snes/examples/tutorials/ex19.c
> I've just pulled and got the following error after typing make test
> [0]PETSC ERROR: PetscCommDestroy() line 246 in
> [0]PETSC ERROR: PetscThreadCommFinalizePackage() line 36 in
> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/threadcomm/interface/dlregisthreadcomm.c
> [0]PETSC ERROR: PetscRegisterFinalizeAll() line 313 in
> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/objects/destroy.c
> [0]PETSC ERROR: PetscFinalize() line 1080 in
> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/objects/pinit.
> I did not configure for a threaded version of PETSc.
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120505/ae64863c/attachment.html>
