[petsc-dev] patches for PetscBagSetFromOptions and associated fortran example
Blaise Bourdin bourdin at lsu.edu
Thu May 3 18:26:45 CDT 2012
I am attaching 2 patches:
* PetscBagSetFromOptions.patch fixes an issue with PetscBagSetFromOptions when the bag contains
  int or real arrays, and addd automatic fortran binding.
* ex5f90.patch uses the transfer function in order to get the bag size instead of computing it
  by hand. With this choice of sizes, padding happens in the fortran derived type and the
  straightforward computation is wrong. I have updated the test output and parameters
Is it possible to push them to petsc-dev?
Blaise
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120503/130b5731/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120503/130b5731/attachment-0001.obj>
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
