[petsc-dev] make test error
John Mousel john.mousel at gmail.com
Tue May 1 14:28:28 CDT 2012
I just pulled petsc-dev and am getting the following error in the tests.
John
Running test examples to verify correct installation
Using PETSC_DIR=/home/vchivukula/NumericalLibraries/petsc-dev and
PETSC_ARCH=linux-intel
Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI
process
See http://www.mcs.anl.gov/petsc/documentation/faq.html
lid velocity = 0.0016, prandtl # = 1, grashof # = 1
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR:
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: [0] PetscSectionCreateGlobalSection line 440
src/vec/vec/impls/seq/vsection.c
[0]PETSC ERROR: [0] DMGetDefaultGlobalSection line 2624
src/dm/interface/dm.c
[0]PETSC ERROR: [0] DMGetDefaultSF line 2656 src/dm/interface/dm.c
[0]PETSC ERROR: [0] DMGlobalToLocalBegin line 1012 src/dm/interface/dm.c
[0]PETSC ERROR: [0] DMDAFunction line 177 src/dm/impls/da/da2.c
[0]PETSC ERROR: [0] DM user function line 0 unknownunknown
[0]PETSC ERROR: [0] DMComputeFunction line 1896 src/dm/interface/dm.c
[0]PETSC ERROR: [0] SNESDefaultComputeFunction_DMLegacy line 379
src/snes/utils/dmsnes.c
[0]PETSC ERROR: [0] SNES user function line 0 unknownunknown
[0]PETSC ERROR: [0] SNESComputeFunction line 1821 src/snes/interface/snes.c
[0]PETSC ERROR: [0] SNESSolve_LS line 143 src/snes/impls/ls/ls.c
[0]PETSC ERROR: [0] SNESSolve line 3395 src/snes/interface/snes.c
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120501/0f4c6f4d/attachment.html>
