[petsc-dev] simple way to use --db-attach with valgrind in parallel with mpiexec
Sat Jun 30 19:51:49 CDT 2012
Did you try this?
mpiexec -n 2 xterm -e valgrind --db-attach=yes ./ex -args
On Sat, Jun 30, 2012 at 4:33 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Has anyone documented a simple way to run parallel programs with
> mpiexec and valgrind and use the --db-attach=yes option to use the debugger
> on a process to see what is going on?
>    My simple minded attempt leads to uselessness; it tries to ask me about
> using the debugger but seems to be in tty hell.
>     Thanks
>     Barry
> barry-smiths-macbook-pro:LuLu barrysmith$
> ~/Src/petsc-dev/arch-gnu/bin/mpiexec -n 2 valgrind --tool=memcheck
> --db-attach=yes --dsymutil=yes --num-callers=20  -q  ./ex26 -ts_type beuler
> --55788-- run: /usr/bin/dsymutil "./ex26"
> --55789-- run: /usr/bin/dsymutil "./ex26"
> error: No such file or directory - old dSYM file cannot be overwritten:
>       old: './ex26.dSYM/Contents/Resources/DWARF/ex26'
>         new:'./ex26.dSYM/Contents/Resources/DWARF/ex26.x86_64'.
> "/Users/barrysmith/Src/petsc-dev/arch-gnu/lib/libpetsc.dylib"
>       old:
> '/Users/barrysmith/Src/petsc-dev/arch-gnu/lib/libpetsc.dylib.dSYM/Contents/Resources/DWARF/libpetsc.dylib'
> new:'/Users/barrysmith/Src/petsc-dev/arch-gnu/lib/libpetsc.dylib.dSYM/Contents/Resources/DWARF/libpetsc.dylib.x86_64'.
> "/Users/barrysmith/Src/petsc-dev/arch-gnu/lib/libparmetis.dylib"
> "/Users/barrysmith/Src/petsc-dev/arch-gnu/lib/libmetis.dylib"
> warning: (x86_64)
> /Users/barrysmith/Src/petsc-dev/externalpackages/mpich2-1.4.1p1/lib/.tmp/wtimef.o
> unable to open object file
> warning: no debug symbols in executable (-arch x86_64)
> 4x4 grid, water viscosity = 1, oil vescosity # = 1,
>  connate water saturation # = 0 irreducible oil saturation # =0
> timestep 0 time 0
> ==55789== Use of uninitialised value of size 8
> ==55789==    at 0x100002B3C: Mobility (ex26.c:116)
> ==55789==    by 0x10000637F: FormIFunctionLocal (ex26.c:579)
> ==55789==    by 0x100007791: FormIFunction (ex26.c:680)
> ==55789==    by 0x100DACF67: TSComputeIFunction (ts.c:374)
> ==55789==    by 0x100DA3778: SNESTSFormFunction_Theta (theta.c:204)
> ==55789==    by 0x100DC2D27: SNESTSFormFunction (ts.c:2560)
> ==55789==    by 0x100CACE87: SNESComputeFunction (snes.c:1901)
> ==55789==    by 0x100CF7651: SNESSolve_LS (ls.c:161)
> ==55789==    by 0x100CBF982: SNESSolve (snes.c:3549)
> ==55789==    by 0x100DA223F: TSStep_Theta (theta.c:114)
> ==55789==    by 0x100DBC4B9: TSStep (ts.c:1827)
> ==55789==    by 0x100DBDA12: TSSolve (ts.c:1951)
> ==55789==    by 0x1000047A8: main (ex26.c:327)
> ==55789==
> ==55789==
> ==55789== ---- Attach to debugger ? --- [Return/N/n/Y/y/C/c] ----
> ==55789== Invalid read of size 8
> ==55789==  Address 0x8 is not stack'd, malloc'd or (recently) free'd
> ==55789==
> ==55789== Conditional jump or move depends on uninitialised value(s)
> ==55789==    at 0x102738F7B: signal__ (in /usr/lib/libSystem.B.dylib)
> ==55789==    by 0x100181B19: PetscDefaultSignalHandler (signal.c:143)
> ==55789==    by 0x1001818AE: PetscSignalHandler_Private (signal.c:53)
> ==55789==    by 0x138048EF3: ???
> ==55789==
> ==55789==    at 0x102738FD7: sigaction (in /usr/lib/libSystem.B.dylib)
> ==55789==    by 0x102738FA6: signal__ (in /usr/lib/libSystem.B.dylib)
> ==55789==
> ==55789==    at 0x102738FDC: sigaction (in /usr/lib/libSystem.B.dylib)
> ==55789==
> ==55789==    at 0x102738FE1: sigaction (in /usr/lib/libSystem.B.dylib)
> ==55789==
> ==55789== Syscall param sigaction(signum) contains uninitialised byte(s)
> ==55789==    at 0x102739032: __sigaction (in /usr/lib/libSystem.B.dylib)
> ==55789==
> ==55789==
> ==55789== Process terminating with default action of signal 11 (SIGSEGV)
> ==55789==  General Protection Fault
> ==55789==    at 0x1027F0FC1: dyld_stub_binder (in
> ==55789==    by 0x101C4549F: ??? (in
> /Users/barrysmith/Src/petsc-dev/arch-gnu/lib/libpetsc.dylib)
> ==55789==    by 0x100181B31: PetscDefaultSignalHandler (signal.c:144)
> ==55788== Invalid read of size 8
> ==55788==    at 0x100006443: FormIFunctionLocal (ex26.c:581)
> ==55788==    by 0x100007791: FormIFunction (ex26.c:680)
> ==55788==    by 0x100DACF67: TSComputeIFunction (ts.c:374)
> ==55788==    by 0x100DA3778: SNESTSFormFunction_Theta (theta.c:204)
> ==55788==    by 0x100DC2D27: SNESTSFormFunction (ts.c:2560)
> ==55788==    by 0x100CACE87: SNESComputeFunction (snes.c:1901)
> ==55788==    by 0x100CF7651: SNESSolve_LS (ls.c:161)
> ==55788==    by 0x100CBF982: SNESSolve (snes.c:3549)
> ==55788==    by 0x100DA223F: TSStep_Theta (theta.c:114)
> ==55788==    by 0x100DBC4B9: TSStep (ts.c:1827)
> ==55788==    by 0x100DBDA12: TSSolve (ts.c:1951)
> ==55788==    by 0x1000047A8: main (ex26.c:327)
> ==55788==  Address 0x1045cf920 is 1,936 bytes inside a block of size 1,940
> alloc'd
> ==55788==    at 0x1000251EF: malloc (vg_replace_malloc.c:236)
> ==55788==    by 0x1000CC71B: PetscMallocAlign (mal.c:37)
> ==55788==    by 0x1000CDF89: PetscTrMallocDefault (mtr.c:190)
> ==55788==    by 0x1002B338B: VecGetArray2d (rvector.c:1759)
> ==55788==    by 0x1009430B0: DMDAVecGetArray (dagetarray.c:72)
> ==55788==    by 0x100007536: FormIFunction (ex26.c:673)
> ==55788==
> ==55788==
> ==55788== ---- Attach to debugger ? --- [Return/N/n/Y/y/C/c] ----
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   EXIT CODE: 11
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120630/f8637668/attachment.html>
