[petsc-dev] slow "ar Scq" on cygwin
Chetan Jhurani chetan.jhurani at gmail.com
Thu Jun 28 21:26:30 CDT 2012
> Look. It does not do that. Ever. In any universe. I don't know what you think you are doing,
> but it is definitely not what you wrote. Look at the code. It can't do that.
I don't think you understand what your code is doing in a new
environment of the same universe.
It works fine on Linux with the steps you had given.
But on the cygwin side, no dependency files like
./lib/libpetsc-obj/adaptbasic.d are created. I found this after
running the python build on Linux (I didn't know before this
where the dependencies were stored).
Here is some debug info in the python code:
In the buildLibraries function on the Linux box (when building in the second step)
  self.sourceDatabase =  DirectedGraph with 1172 vertices and 21894 edges
However, on the cygwin side (again, when building the second time)
 self.sourceDatabase =  <builder.NullSourceDatabase object at 0xffd833ac>
So of course it is totalRebuild = true on cygwin.
I don't mind extra debugging on cygwin/Windows before reporting issues
since I know the petsc project has many other priorities. But a few useful
debugging pointers will be serve both of us better.
Chetan
From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Matthew Knepley
Sent: Thursday, June 28, 2012 6:00 PM
To: For users of the development version of PETSc
Subject: Re: [petsc-dev] slow "ar Scq" on cygwin
On Thu, Jun 28, 2012 at 4:49 PM, Chetan Jhurani <chetan.jhurani at gmail.com> wrote:
> > $ PETSC_DIR=/cygdrive/d/petsc-dev-2012-06-26 PETSC_ARCH=test_8 ./config/builder.py
> > (The same happens (existing .o are deleted) if ./config/builder2.py build is used)
> This is not what I wrote. You used builder.py, which is python 2.4 compatible, but has to do everything without options,
> so yes it deletes all the objects and rebuilds everything. That is why I did not suggest you use it.
> I said to use builder2.py, which does proper dependency tracking.
That is what I used and I mentioned it above. I've tried both separately.
Both give the same result that libpetsc.lib is not created.  And
whether I use builder.py or builder2.py, the existing objects
files are deleted in the second build. I did not call for a cleanup.
  matt
To be sure, I tried the whole thing in a new ARCH with a fresh
configure step, and this time builder.py was not used at all (by me)
but it led to the same issues with builder2.py.
I understand that this is not the most used platform, so let me
know if I can be of help.  And I forgot to mention that the
python build was 4-5 times faster than "ar" based build and
that's great...
Chetan
Sent: Thursday, June 28, 2012 3:21 PM
On Thu, Jun 28, 2012 at 4:10 PM, Chetan Jhurani <chetan.jhurani at gmail.com> wrote:
Matt,
I was surprised too on both counts. Couldn't find any libpetsc.lib after the python build
and I did not run "clean" in between that could have deleted the .o files.
Here's one more try below to show it.
$ ls test_8/lib/
libpetsc-obj
$ ls test_8/lib/libpetsc-obj/ | wc -l
560
   Matt
Rebuilding Dependencies
Building in /cygdrive/d/petsc-dev-2012-06-26/src/sys
Building in /cygdrive/d/petsc-dev-2012-06-26/src/sys/bag
Building in /cygdrive/d/petsc-dev-2012-06-26/src/sys/comm
Building in /cygdrive/d/petsc-dev-2012-06-26/src/sys/dll
I stopped the build using control-c.  It would have deleted all files first.
Traceback (most recent call last):
  File "./config/builder.py", line 1534, in <module>
    PETScMaker().run()
  File "./config/builder.py", line 1526, in run
    if self.buildLibraries('libpetsc', self.rootDir):
  File "./config/builder.py", line 1331, in buildLibraries
    objects += self.buildDir(root, files, objDir)
  File "./config/builder.py", line 1251, in buildDir
    objects.extend(getattr(self, 'compile'+language)(sourceMap[language], objDir))
  File "./config/builder.py", line 1025, in compileC
    return self.compile(self.configInfo.languages.clanguage, source, objDir)
  File "./config/builder.py", line 1012, in compile
    (output, error, status) = self.executeShellCommand(cmd, checkCommand = noCheckCommand, log=self.log)
  File "/cygdrive/d/petsc-dev-2012-06-26/config/BuildSystem/script.py", line 254, in executeShellCommand
    (output, error, status) = runInShell(command, log, cwd)
  File "/cygdrive/d/petsc-dev-2012-06-26/config/BuildSystem/script.py", line 243, in runInShell
    thread.join(timeout)
  File "/usr/lib/python2.6/threading.py", line 655, in join
    self.__block.wait(delay)
  File "/usr/lib/python2.6/threading.py", line 258, in wait
    _sleep(delay)
KeyboardInterrupt
bag.o
All the previous .o were deleted.  Perhaps I'm not doing something right?
Chetan
Sent: Thursday, June 28, 2012 2:46 PM
On Thu, Jun 28, 2012 at 3:31 PM, Chetan Jhurani <chetan.jhurani at gmail.com> wrote:
Thanks Matt, Satish.  A few issues though.
Like you said, the latest cygwin has python 2.6.8 which
does not have argparse.  When I place the following
in path http://argparse.googlecode.com/svn/trunk/argparse.py
I can run the python build with 2.6.8.
However, the "ar" based build had worked fine and the python
based build fails for these two files.
  src/snes/impls/MULTIB~1/multiblock.c
  src/snes/impls/vi/rsaug/virsaug.c
Yep, it fails, but the build succeeds, so no problem.
It looks like these two files were NOT compiled in the ar based
build. The two make.log files are attached.
One more question. I tried to run the python based build
the second time (after it was unsuccessful the first time)
and then it deleted all the previous .o files it had created in
ARCH/lib/libpetsc-obj.  How can that be avoided?
It does not do that unless you run 'clean'.
   Matt
Chetan
Sent: Thursday, June 28, 2012 1:35 PM
On Thu, Jun 28, 2012 at 2:23 PM, Chetan Jhurani <chetan.jhurani at gmail.com> wrote:
Hi devs,
Is there a way to avoid running the archiver (ar)
every time a petsc directory is compiled?
The reason I'm asking this is that when libpetsc.lib
becomes large enough (say 100MB+, esp. for debug build),
"ar Sqc" on cygwin takes very long in each directory.
Depending on OS caching, very long can be 10 seconds per
PETSc directory just to run ar.
It creates a new temp file from scratch, puts stuff from
libpetsc.lib and new stuff in it and then renames the
temp file.  As you can imagine, the compilation process is
fast in the beginning but crawls by the end.  I've seen
the same IO sequence on Linux (with Sqc flags to ar), but
since cygwin IO is slower the effect is more clearly visible.
Building within a ramdisk leads to 25% faster compilation
but it was more of a curiosity.
Build with Python. It never uses antique things like ar :)
  python2.7 ./config/builder2.py build
     Matt
Chetan
What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to
which their experiments lead.
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120628/9a8ba612/attachment.html>
