[petsc-dev] Modifying code in seqcusp folder
Fri Jun 22 16:40:42 CDT 2012
On Thu, 21 Jun 2012, Matthew Knepley wrote:
> On Thu, Jun 21, 2012 at 1:48 PM, Chekuri Choudary
> <cchoudary at rnet-tech.com>wrote:
> > Typically, when I make changes to petsc code, I do a make lib in the
> > folder and then recompile my code. That doesn’t seem to be working in
> > seqcusp folder. I do a make lib and nothing happens. Can somebody please
> > help??
> Yes, the check for stale CUDA code was broken. Satish, did this get fixed
> or is it still broken?
Now fixed in petsc-dev
http://petsc.cs.iit.edu/petsc/petsc-dev/rev/587a2035630d
http://petsc.cs.iit.edu/petsc/BuildSystem/rev/f247c0b6e88b
Satish
