[petsc-dev] PetscLogView vs. -log_summary
Thu Jun 21 22:46:35 CDT 2012
On Thu, Jun 21, 2012 at 4:16 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jun 21, 2012, at 3:40 PM, Matthew Knepley wrote:
> > On Thu, Jun 21, 2012 at 2:08 PM, Blaise Bourdin <bourdin at lsu.edu> wrote:
> > On Jun 21, 2012, at 2:55 PM, Matthew Knepley wrote:
> >> On Thu, Jun 21, 2012 at 1:11 PM, Blaise Bourdin <bourdin at math.lsu.edu>
> wrote:
> >> Hi,
> >> PetscLogView does not display the same amount of information as running
> with -log_summary. In the "summary of stages" section, the former contains
> only information on the main stage while the later contains much more.
> >> Add the following block at the end of
> src/snes/examples/tutorials/ex1.c, for instance, to see what I mean
> >>  PetscViewer viewer;
> >>  ierr =
> PetscViewerASCIIOpen(PETSC_COMM_WORLD,"ex1-log.py",&viewer);CHKERRQ(ierr);
> >>  ierr = PetscLogViewPython(viewer);CHKERRQ(ierr);
> >>  ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
> >>  ierr =
> PetscViewerASCIIOpen(PETSC_COMM_WORLD,"ex1-log.txt",&viewer);CHKERRQ(ierr);
> >>  ierr = PetscLogView(viewer);CHKERRQ(ierr);
> >>  ierr =
> PetscLogPrintDetailed(PETSC_COMM_WORLD,"ex1-logdetailed.txt");CHKERRQ(ierr);
> >> Is this a bug or a feature? Is there a way to get the same output as
> -log_summary in a file, without printing it to stdout?
> >> -log_summary just calls PetscLogView(). I am not sure how there could
> be a problem. I will run it. However, can you
> >> just use
> >>   -log_summary <filename>
> > That works, yes. Is the issue that stages / events need to be activated
> a priori, which is not possible when PetscLogView is only called at the end
> of the program?
> > Crap.
>    Matt,  why is this "Crap"   its completely reasonable that if you want
> to have logging from program control that you have to turn it on
> programatically?
Crap, because I should have remembered earlier.
   Matt
> > If you do not provide -log_summary, you need PetscLogBegin() at the
> beginning.
> >    Matt
> > The caveat is that I am assuming that when using log_summary, the log is
> written as part of PetscFinalize, so that if a job is killed by the
> sceduler or the user, there is no way to get an idea of the performances. I
> like to print the log every so often.
> > Blaise
> > Department of Mathematics and Center for Computation & Technology
> > Louisiana State University, Baton Rouge, LA 70803, USA
> > Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> http://www.math.lsu.edu/~bourdin
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120621/d04d9592/attachment.html>
