[petsc-dev] Getting "from" and "to" IS from a VecScatter
Wed Jun 20 19:23:51 CDT 2012
  Why do you need them? Maybe there is a better way?
On Jun 20, 2012, at 6:19 PM, Blaise Bourdin wrote:
> Hi,
> I need to reconstruct the IS that were used to build a VecScatter between a local and a global Vec.
> From what I see in VecScatterView_MPI (vpscat.c:13), it looks like I can get the indices from from->local.vslots[i],to->local.vslots[i], i=0 .. i<to->local.n where from and to are obtained with
>  VecScatter_MPI_General *to=(VecScatter_MPI_General*)ctx->todata;
>  VecScatter_MPI_General *from=(VecScatter_MPI_General*)ctx->fromdata;
> From there, constructing the IS is trivial. Is there a way that does not involve poking inside the VecScatter data structure?
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
