[petsc-dev] [petsc-users] make test failed
Wed Jun 20 16:09:08 CDT 2012
  Add a little python function that is called at the beginning of ./configure that goes through all the scripts and removes \r if they exist in the scripts.
  On non-Windows the function will do nothing and on Windows if either Mecurial or properly extracted tarball will do nothing. Will only do something if user extracted tarball wrong.
   Problem solved, doesn't require changing anything else in PETSc.
   Barry
On Jun 19, 2012, at 11:51 PM, Satish Balay wrote:
> On Tue, 19 Jun 2012, Barry Smith wrote:
>>> It appears that the extra '\r' char is causing bash to process strings
>>> incorrectly.
>> Yes, but exactly how? Run the winzip to get the extra \r in
>> them.
> BTW: unix2dos is equivalent to winzip wrt reproduction.
>> Then start removing them as you run the script to determine
>> exactly where the grief comes from. I do not think the extra \r are
>> always harmful, just if they come up in the wrong place. If you
>> determine this you can reformat the original code to not have the
>> bad \r cause grief.
> Assume the extra char is 'x' [instead of '\r'] for illustration.
> i.e:
> var='foo'\r
> is represented as
> var='foo'x
> Note: the above is valid syntax [but 'var' will have extra stuff that
> wasn't intended]
> The primary issue is - if you have the following code [in dos formatted text]:
> if [ 'a' == 'a']
> then
>  echo "yes"
> else
>  echo "no"
> fi
> It is interpreted as:
> if [ 'a' == 'a']x
> thenx
>  echo "yes"x
> elsex
>  echo "no"x
> fix
> And you get the error "syntax error: unexpected end of file"
> One way to workarround is to add 'var=foo' before '\r' and
> get some valid bash syntax. i.e something like:
> if [ 'a' == 'a'] then a='a'x
>  echo "yes"; a='a'x
> else a='a'x
>  echo "no"; a='a'x
> fi; a='a'x
> So the fixed mpiexec.uni looks something like:
> $ cat mpiexec.uni
> #!/bin/sh
> if [ $1 !=  "-np" -a $1 != "-n" ]; then a=a
> progname=$*; a=a
> elif  [ $2 =  "1" ]; then a=a
> shift ; shift; a=a
> progname=$* ; a=a
> else a=a
> echo "Uniprocessor version of MPI can only use one processor"; a=a
> exit 1; a=a
> fi; a=a
> a=a
> # Execute the program
> $progname;a=a
> exit 0;a=a
> There is an alternative of setting the following env before running
> bash scripts in cygwin - but these commands appear to be cygwin/bash
> specific [so cannot easily automate?]
> export SHELLOPTS
> set -o igncr
> <now run the script>
> Satish
