[petsc-dev] call stack
John Fettig john.fettig at gmail.com
Wed Jun 20 09:38:59 CDT 2012
You can use hpctoolkit to profile the cpu portion, it does exactly
what you are asking.  To profile the cuda portion, you will have to
use nvidia's visual profiler.
John
On Wed, Jun 20, 2012 at 4:32 AM, Luigia Ambrosio
<ambrosio.luigia at gmail.com> wrote:
> Hi all
> I'm interested in using PETSC with CUDA. I just downloaded and installed the
> developer version and I was testing the example #1
> ($HOME/petsc-dev/src/vec/vec/examples/tutorials) to compute the norm of a
> vector.
> I would like to compare PETSC "without cuda" and "with cuda". Is there a way
> to profile a PETSC executable, obtain the stack of the called functions and
> methods and access to the function body?
> Can anybody make an exmple?
> Thanks a million
