[petsc-dev] call stack
Wed Jun 20 07:21:09 CDT 2012
On Wed, Jun 20, 2012 at 3:18 AM, Luigia Ambrosio
<ambrosio.luigia at gmail.com>wrote:
> Yes but it's not enough! I nedd the stack of the called methods and
> kernels.
> I just sent you my modified ex11 and the results of ./ex11 -log_summary
Use the debugger. Its the easiest way to get a stack. However, for the old
people here, it
is also possible to do by looking at the source code.
   Matt
> thanks again
> Luigia Ambrosio
> Il giorno 20/giu/2012, alle ore 10:45, Aron Ahmadia ha scritto:
> Have you tried passing -log_summary to the command line?
> A
> On Wed, Jun 20, 2012 at 11:32 AM, Luigia Ambrosio <
> ambrosio.luigia at gmail.com> wrote:
>> Hi all
>> I'm interested in using PETSC with CUDA. I just downloaded and installed
>> the developer version and I was testing the example #1
>> ($HOME/petsc-dev/src/vec/vec/examples/tutorials) to compute the norm of a
>> vector.
>> I would like to compare PETSC "without cuda" and "with cuda". Is there a
>> way to profile a PETSC executable, obtain the stack of the called functions
>> and methods and access to the function body?
>> Can anybody make an exmple?
>> Thanks a million
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120620/afc10170/attachment.html>
