[petsc-dev] [petsc-users] make test failed
Tue Jun 19 15:53:32 CDT 2012
On Jun 19, 2012, at 3:33 PM, Satish Balay wrote:
> On Tue, 19 Jun 2012, Barry Smith wrote:
> '\n'.
> It appears that the extra '\r' char is causing bash to process strings
> incorrectly.
   Yes, but exactly how? Run the winzip to get the extra \r in them. Then start removing them as you run the script to determine exactly where the grief comes from. I do not think the extra \r are
always harmful, just if they come up in the wrong place. If you determine this you can reformat the original code to not have the bad \r cause grief.
   Barry
> Presumably 'winzip' or similar tool created all text files
> [sources,makefiles,scripts] etc in the dos mode.
> Satish
>>  Barry
>>> If this is the case - perhaps converting it it from bash to python is
>>> the way to go? [as python is unaffected by dos format - configure ran
>>> fine]
>>> Satish
