[petsc-dev] SNESLineSearchApply_BT logic divergence
Daniel Lowell redratio1 at gmail.com
Fri Jun 15 11:10:00 CDT 2012
Are there any other values cached by the vector?
On Fri, Jun 15, 2012 at 11:06 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Jun 16, 2012 at 12:03 AM, Daniel Lowell <redratio1 at gmail.com>wrote:
>> Hey Satish,
>> So I'm having an issue with this function:
>> *#define PetscObjectComposedDataGetReal <http://www.mcs.anl.gov/petsc/petsc-current/include/petsc-private/docs/manualpages/Sys/PetscObjectComposedDataGetReal.html#PetscObjectComposedDataGetReal>(obj,id,data,flag)                            \**((((obj)->realcomposedstate && ((obj)->realcomposedstate[id] == (obj)->state))?  \**(data = (obj)->realcomposeddata[id],flag = PETSC_TRUE <http://www.mcs.anl.gov/petsc/petsc-current/include/petsc-private/docs/manualpages/Sys/PETSC_TRUE.html#PETSC_TRUE>) : (flag = PETSC_FALSE <http://www.mcs.anl.gov/petsc/petsc-current/include/petsc-private/docs/manualpages/Sys/PETSC_FALSE.html#PETSC_FALSE>)),0)*
>> Called from VecNorm which is called from SNESLineSearchApply_BT
>> I have two examples running one is the vanilla ex14 using my GPU vector
>> and matrix type.  The other example is a variant of ex14test where I am
>> implementing GPU formfunction and formjacobian.
>> ex14 vanilla runs through correctly, however ex14test diverges in the
>> logic within VecNorm, specifically line 164:
>>    * Cached data?
>>   if (type!=NORM_1_AND_2) {
>>     ierr = PetscObjectComposedDataGetReal
>> ((PetscObject)x,NormIds[type],*val,flg);CHKERRQ(ierr);
>>     if (flg) PetscFunctionReturn(0);
>> The ex14 detects there is a "real" part, however the ex14test does not
>> and VecNorm returns.
>> "val" in VecNorm is PetscReal gnorm = fnorm defined in
>> SNESLineSearchApply_BT.
>> For ex14:       val[0]=3.44e-317, val[1]: 0.580
>> For ex14test: val[0]=3.44e-317, val[1]: 0.029
>> This difference makes SNESLineSearchApply_BT branch into different
>> execution paths.
>> I'm not sure where the issue could have come from. Any ideas?
> If you change values in a Vec, you must increment the internal state,
> since we cache norms.
> The internal functions for array getting do this automatically, so I am
> not sure why this is
> messing up. Did you bypass them?
>    Matt
>> Daniel Lowell
> experiments lead.
> -- Norbert Wiener
Daniel Lowell
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120615/849495d3/attachment.html>
