[petsc-dev] error reading binary file
Mark F. Adams mark.adams at columbia.edu
Tue Jun 12 16:47:28 CDT 2012
Split ownership is not respecting blocks:
[0]PETSC ERROR: PetscSplitOwnership() line 93 in /Users/markadams/Codes/petsc-dev/src/sys/utils/psplit.c
On Jun 12, 2012, at 5:33 PM, Jed Brown wrote:
> On Tue, Jun 12, 2012 at 4:35 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> And I now get the following error when I try to run this in parallel.
> Note, Blaise, I do not have coordinates, so perhaps you could check that you still get divergence w/o coordinates.  (I don't need anything else form you)
> Did you apply the patch? I ran that code in parallel using ./ex10 -f0 binaryoutput-sym
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120612/6763dc45/attachment.html>
