[petsc-dev] error reading binary file
Mark F. Adams mark.adams at columbia.edu
Tue Jun 12 16:06:27 CDT 2012
On Jun 12, 2012, at 4:56 PM, Jed Brown wrote:
> On Tue, Jun 12, 2012 at 3:54 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> How is what?  The ex10 code or "I set the block size for matrices before SetFromOptions".
> This how I create matrices with blocks sizes:
>   ierr = MatCreate( wcomm, &Prol ); CHKERRQ(ierr);
>   ierr = MatSetSizes(Prol,nloc*bs,nLocalSelected*col_bs,PETSC_DETERMINE,PETSC_DETERMINE);
>   CHKERRQ(ierr);
>   ierr = MatSetBlockSizes( Prol, bs, col_bs ); CHKERRQ(ierr);
> Sorry, I thought you were talking about vectors because the error is coming from a vector load.
There is a vector load, at least ex10 loads a vec and its seems to work (so I assume Blaise put one in there).
> Where is this input file? I'll grab it sort out the issue.
You can get an archive containing the KSP and the data files at https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/52338Q0at2Y
These are just standard "binaryoutput" files I think,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120612/6274e9dd/attachment.html>
