[petsc-dev] error reading binary file
Mark F. Adams mark.adams at columbia.edu
Tue Jun 12 13:59:26 CDT 2012
On Jun 12, 2012, at 1:53 PM, Matthew Knepley wrote:
> On Wed, Jun 13, 2012 at 1:49 AM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> I have: ~/Desktop/GAMG>cat binaryoutput-sym.info
> -vecload_block_size 3
> I need the matrix block size to be set...
> Then you need to disambiguate among vectors with prefixes.
How does one do that?  Blaise generated this mat/vec.
>    Matt
> Mark
> On Jun 12, 2012, at 12:42 PM, Jed Brown wrote:
>> Look at the *.info file.
>> On Tue, Jun 12, 2012 at 11:45 AM, Mark F. Adams <mark.adams at columbia.edu> wrote:
>> I'm getting this error when I try to read a matrix/vector with block size 3:
>> ~/Desktop/GAMG>./ex10 -f0  binaryoutput-sym
>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [0]PETSC ERROR: Arguments are incompatible!
>> [0]PETSC ERROR: Cannot change block size 1 to 3!
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Petsc Development HG revision: 4c35227011f74c2367a3a96a62bc4d6df701bcfb  HG Date: Sun Jun 10 00:30:22 2012 -0500
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR: ./ex10 on a arch-maco named madams-macbk-3.local by markadams Tue Jun 12 12:39:02 2012
>> [0]PETSC ERROR: Libraries linked from /Users/markadams/Codes/petsc-dev/arch-macosx-gnu-O/lib
>> [0]PETSC ERROR: Configure run at Mon Jun 11 15:15:38 2012
>> [0]PETSC ERROR: Configure options CXX=/sw/lib/gcc4.6/bin/g++-4 CC=/sw/lib/gcc4.6/bin/gcc-4 CFLAGS=-malign-double CXXFLAGS=-malign-double FC=/sw/lib/gcc4.6/bin/gfortran --download-parmetis=1 --download-metis=1 --download-hdf5=1 --download-hypre=1 --download-ml=1 --download-prometheus=1 --download-triangle=1 --with-x=0 --with-debugging=0 --download-mpich=1 PETSC_ARCH=arch-macosx-gnu-O
>> [0]PETSC ERROR: PetscLayoutSetBlockSize() line 460 in /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pmap.c
>> [0]PETSC ERROR: VecSetBlockSize() line 1526 in /Users/markadams/Codes/petsc-dev/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: VecLoad_Binary() line 104 in /Users/markadams/Codes/petsc-dev/src/vec/vec/utils/vecio.c
>> [0]PETSC ERROR: VecLoad_Default() line 348 in /Users/markadams/Codes/petsc-dev/src/vec/vec/utils/vecio.c
>> [0]PETSC ERROR: VecLoad() line 1111 in /Users/markadams/Codes/petsc-dev/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: main() line 132 in src/ksp/ksp/examples/tutorials/ex10.c
>> application called MPI_Abort(MPI_COMM_WORLD, 75) - process 0
>> [unset]: aborting job:
>> ~/Desktop/GAMG>
>> I just want to check if anyone has any thoughts before I start digging into this.
>> Mark
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120612/fa35b7ab/attachment.html>
