[petsc-dev] error reading binary file
Tue Jun 12 11:42:47 CDT 2012
Look at the *.info file.
On Tue, Jun 12, 2012 at 11:45 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> I'm getting this error when I try to read a matrix/vector with block size
> 3:
> ~/Desktop/GAMG>./ex10 -f0  binaryoutput-sym
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Arguments are incompatible!
> [0]PETSC ERROR: Cannot change block size 1 to 3!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Development HG revision:
> 4c35227011f74c2367a3a96a62bc4d6df701bcfb  HG Date: Sun Jun 10 00:30:22 2012
> -0500
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./ex10 on a arch-maco named madams-macbk-3.local by
> markadams Tue Jun 12 12:39:02 2012
> [0]PETSC ERROR: Libraries linked from
> /Users/markadams/Codes/petsc-dev/arch-macosx-gnu-O/lib
> [0]PETSC ERROR: Configure run at Mon Jun 11 15:15:38 2012
> [0]PETSC ERROR: Configure options CXX=/sw/lib/gcc4.6/bin/g++-4
> CC=/sw/lib/gcc4.6/bin/gcc-4 CFLAGS=-malign-double CXXFLAGS=-malign-double
> FC=/sw/lib/gcc4.6/bin/gfortran --download-parmetis=1 --download-metis=1
> --download-hdf5=1 --download-hypre=1 --download-ml=1
> --download-prometheus=1 --download-triangle=1 --with-x=0 --with-debugging=0
> --download-mpich=1 PETSC_ARCH=arch-macosx-gnu-O
> [0]PETSC ERROR:
> [0]PETSC ERROR: PetscLayoutSetBlockSize() line 460 in
> /Users/markadams/Codes/petsc-dev/src/vec/vec/impls/mpi/pmap.c
> [0]PETSC ERROR: VecSetBlockSize() line 1526 in
> /Users/markadams/Codes/petsc-dev/src/vec/vec/interface/vector.c
> [0]PETSC ERROR: VecLoad_Binary() line 104 in
> /Users/markadams/Codes/petsc-dev/src/vec/vec/utils/vecio.c
> [0]PETSC ERROR: VecLoad_Default() line 348 in
> [0]PETSC ERROR: VecLoad() line 1111 in
> [0]PETSC ERROR: main() line 132 in src/ksp/ksp/examples/tutorials/ex10.c
> application called MPI_Abort(MPI_COMM_WORLD, 75) - process 0
> [unset]: aborting job:
> ~/Desktop/GAMG>
> I just want to check if anyone has any thoughts before I start digging
> into this.
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120612/6b0abdc7/attachment.html>
