[petsc-dev] New DMDA boundary type?
Richard Katz Richard.Katz at earth.ox.ac.uk
Fri Jun 8 09:18:17 CDT 2012
Hi all,
Writing to ask that you again consider this feature request.
Rich
On Jan 8, 2012 2:43 PM, "Richard Katz" <richard.katz at earth.ox.ac.uk> wrote:
> Dear all,
> I wonder if I can interest you in a new DMDA boundary type... that I'd probably need for you to implement... and it might be slightly painful.
> The idea is a periodic boundary with a 180 degree topological "twist." (i.e. Mobius strip in 2D).  I'll call it DMDA_BOUNDARY_PERIODIC_TWIST here for sake of argument.
> If I have a 1D DMDA, this is meaningless.
> If I have a 2D array with DMDA_BOUNDARY_PERIODIC_TWIST as my periodic type in the y-direction, then the row of ghost points at the y-limits of the grid would be as for DMDA_BOUNDARY_PERIODIC, but with the order of values in the x-direction reversed.
> In 3D this would be more complicated, because a PERIODIC_TWIST boundary condition in one direction could involve twists in either/both of the other directions.
> I'd be thrilled with just the 2D version.  What do you think?
> Cheers,
> Rich
> ps - my motivation: consider a 2D fluid undergoing simple shear as a background strain-rate field.  I am solving for a perturbation to this background field. I would like the perturbation to be periodic in all directions.  Because the perturbation field is advected by the background field, this can only work with Mobius-strip periodicity in the direction normal to the shear direction.
On 23 May 2012, at 15:27, Jed Brown wrote:
> We're basically in code freeze for the 3.3 release now, but I will get back to this. Sorry for dragging on.
