[petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
Thu Jun 7 15:55:16 CDT 2012
On Thu, 7 Jun 2012, Jed Brown wrote:
> On Thu, Jun 7, 2012 at 3:45 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > This is a usage without commits - only local changes/edits - and then 'pull -u'
> Okay, then I agree that this is awkward. Do you get a consistent state if you
> $ hg -R config/BuildSystem pull -u
> $ hg pull -u
Same behavior as before [with .hgsubstate not updated - and showing as modified wrt current parent]
Satish
[balay at maverick petsc-buildsystem-dev]$ hg -q in -S
23599:7c0333892302
23600:007d9928edc8
2828:1c53f750b541
2829:6548b4f26bd1
2830:03ab1f7aeb3a
2831:6ab6f1ae4aff
[balay at maverick petsc-buildsystem-dev]$ hg -q out -S
[balay at maverick petsc-buildsystem-dev]$ hg st -S
M config/BuildSystem/config/packages/BlasLapack.py
M config/examples/asterix/asterix64.py
[balay at maverick petsc-buildsystem-dev]$ hg -R config/BuildSystem pull -u
running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/BuildSystem-subrepo serve --stdio'
pulling from ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
searching for changes
all local heads known remotely
adding changesets
adding manifests
adding file changes
added 4 changesets with 4 changes to 4 files
resolving manifests
getting config/setCompilers.py
getting jeff
getting joe
getting urlMappingLocal.py
4 files updated, 0 files merged, 0 files removed, 0 files unresolved
[balay at maverick petsc-buildsystem-dev]$ hg pull -u
running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/petsc-buildsystem-dev serve --stdio'
pulling from ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
adding changesets
adding manifests
adding file changes
added 2 changesets with 3 changes to 2 files
resolving manifests
resolving manifests
0 files updated, 0 files merged, 0 files removed, 0 files unresolved
getting makefile
1 files updated, 0 files merged, 0 files removed, 0 files unresolved
M .hgsubstate
