[petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
Wed Jun 6 15:40:36 CDT 2012
On Wed, 6 Jun 2012, Barry Smith wrote:
> On Jun 6, 2012, at 2:57 PM, Sean Farley wrote:
> >>> A) make buildsystem a subrepo (svn external for those familiar with svn)
> >>   There have already been many discussions on petsc-dev about how hg subrepos suck and don't satisfy all our needs.
> > That's why I asked about a current list to see exactly what need isn't
> > met.
>      Check the old email. Satish and Matt had specific concerns.
One of the concerns we discussed earlier is the additional
requirement: 'subrepo' usage should be same/similar to 'single repo'
usage. This clearly is not possible with (A). [we have to buy into the
sub-repo model and use it appropriately].
i.e be aware which commands work with subrepos by default - and which
ones need '-s' for subrepo - and then be aware that buildsystem you
pull is not the latest [only the latest commited to petsc-dev] etc.
I don't remember other issues that came up witht he model. Perhaps
'pull -u' is different than 'pull;update'? similar to the currently
recommended hook?
> > So far, I only have that older mercurial clients wouldn't be able
> > to push (but pulling should work fine); so all devs would need a
> > recent mercurial client.
>    As I mentioned in my email to Jed. There needs to be a way to enforce the use of a recent mercurial client.
> >>> B) merge buildsystem into petsc-dev and use graft / transplant to
> >>> maintain a separate repo
> >>   Yuck.
> > Yuck? Everyone would win: Matt would have his separate repo and there
> > would be no more unsynchronized changesets.
>     It sounds hacky. If it is not hacky and Matt is fine with this then we could go that route.
The primary drawback is the initial merge of 'petsc-dev +
buildsystem'.  [new clones by everyone? How does merge from petsc-33
to petsc-dev work after this new clone?]
the stand-alone buildsystem from this merged repo can be automated to
some extent. [with 'hg convert' - it can do incremental updates from
merged-petsc-dev to standalone-buildsystem]. Not sure if there are
corner case - [what if some buildsystem files spill over outside
'buildsystem sub-dir' etc..]
Satish
