[petsc-dev] switch petsc-dev to use --with-shared-libraries by default?
Fri Jun 1 18:40:47 CDT 2012
On Jun 1, 2012, at 1:18 PM, Satish Balay wrote:
> I think the problems come from different types of externalpackage
> usages. [for ex: mpi not built shared]. Also we don't explicitly build
> all externalpackages shared - and this can cause grief in some
> cases. [they just get pulled into libpetsc.so]
> We had this default for a while and then gaveup. But now that we
> default to --with-single-library=1 - some of those issues don't bite
> us..
   Maybe after the release is well tested we can try changing the default in the nightly builds.
   Note that making --with-shared-libraries=1 the default doesn't need to mean that shared library works on every two-bit obscure machines. On machines where shared libraries don't work the user would just us --with-shared-libraries=0
   Barry
> Satish
> On Fri, 1 Jun 2012, Barry Smith wrote:
>>    Is it time to change in petsc-dev the default of --with-shared-libraries to true by default? It is a nicer user experience to use shared libraries (much faster link of executable for example).
>>    Does it work pretty much everywhere?
>>   Barry
