[petsc-dev] What needs to be done before a release?
Fri Jun 1 11:44:56 CDT 2012
Ok - nightly builds on opensolaris has the following error.
      character(kind=c_char),pointer   :: nullc => null()
      Character(kind=C_char,len=99),Dimension(:),Pointer::list1
/export/home/petsc/soft/mpich2-1.2.1p1/bin/mpif90  -D__INSDIR__="" -O -moddir=include -M/export/home/petsc/petsc33/include -M/export/home/petsc/petsc33/arch-opensolaris-pkgs-opt/include -M/export/home/petsc/soft/mpich2-1.2.1p1/include -I/export/home/petsc/petsc33/include -I/export/home/petsc/petsc33/arch-opensolaris-pkgs-opt/include -I/export/home/petsc/soft/mpich2-1.2.1p1/include -c /export/home/petsc/petsc33/src/sys/objects/f2003-src/fsrc/optionenum.F -o CMakeFiles/petsc.dir/src/sys/objects/f2003-src/fsrc/optionenum.F.o
      CArray = (/(c_loc(list1(i)),i=1,Len),c_loc(nullc)/)
"/export/home/petsc/petsc33/src/sys/objects/f2003-src/fsrc/optionenum.F", Line = 33, Column = 25: ERROR: C_LOC function argument must be a variable that has the TARGET attribute and is interoperable, or an allocated allocatable variable that has the target attribute and has interoperable type and type parameters.
"/export/home/petsc/petsc33/src/sys/objects/f2003-src/fsrc/optionenum.F", Line = 33, Column = 50: ERROR: C_LOC function argument must be a variable that has the TARGET attribute and is interoperable, or an allocated allocatable variable that has the target attribute and has interoperable type and type parameters.
f90comp: 3218 SOURCE LINES
f90comp: 2 ERRORS, 0 WARNINGS, 0 OTHER MESSAGES, 0 ANSI
*** Error code 1
How to fix?
thanks,
Satish
On Thu, 31 May 2012, Satish Balay wrote:
> Barry is looking at using this flag and reorganizing the f2003 code.
> [perhaps the interface functions that need this functionality won't be
> compiled selectively - based on this flag]
> Satish
> On Thu, 31 May 2012, Jed Brown wrote:
> > So how do we deal with this function not being implemented unless an F2003
> > compiler is used? Just #ifdef its body and produce a run-time error when an
> > old compiler is used? Satish, are you doing this?
> > On Thu, May 31, 2012 at 11:36 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Added configure check.
> > > http://petsc.cs.iit.edu/petsc/releases/BuildSystem-3.3/rev/a6a959d40d3d
> > > Satish
> > > > And we have our first petsc-maint breakage due to this Fortran 2003
> > > thingy.
> > > > On Thu, May 31, 2012 at 9:03 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > > > This code is using "use,intrinsic :: iso_c_binding"
> > > > > Isn't this a fortran 2003 thingy? Perhaps there should be a configure
> > > > > checks for it.
> > > > > Satish
> > > > > On Wed, 30 May 2012, Barry Smith wrote:
> > > > > >    Blaise,
> > > > > >     I have pushed PetscOptionsGetEnum() and PetscBagRegisterEnum()
> > > for
> > > > > f90 to petsc-dev tests are in src/sys/examples/tutorials
> > > > > >    Barry
