[petsc-dev] Semismooth Newton
Mon Jul 30 18:54:26 CDT 2012
I think we should:
1. change SNESVI to support general complementarity constraints because
only doing box constraints on state variables is lame
2. have a mode to solve the system in the full space, instead of
eliminating the semi-smooth variables (which produces the bad conditioning)
3. eventually allow the dimension of the constraint space to change on each
SNES iteration (would be fantastic for implicit contact)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120730/92431593/attachment.html>
