[petsc-dev] Regression tests
Sat Jul 28 15:52:50 CDT 2012
On Sat, Jul 28, 2012 at 6:53 AM, Gerard Gorman <g.gorman at imperial.ac.uk>wrote:
> Slightly off topic - but I have Buildbot set up locally to keep an eye
> on petsc-dev and various branches of petsc that I care about (if you are
> curious see http://stereolab.ese.ic.ac.uk:8080/waterfall - knock
> yourself out with the force build button if you wish)
> Because this is a bot, 99% of time I only care about "pass", "fail" ($?
> != 0 is counted as a fail), "warning". For the testharness in our own
> application code we just parse the output of unit tests for "pass",
> "fail" and "warning" and list the tests that gave a warning or fail at
> the end so a developer can take a closer look. I would like to do a
> similar grepping for PETSc tests. Are the tests messages standardised so
> I can do this? At first glance I have:
> "pass" == "run successfully with"
> "warning" == "Possible problem with"
> "fail" == "mpiexec not found" or $? != 0
I think you want
http://petsc.cs.iit.edu/petsc/petsc-dev/annotate/c11230be07bd/bin/maint/checkBuilds.py
for builds, and what you have for tests.
   Matt
Cheers
> Gerard
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120728/1dbcf39d/attachment.html>
