[petsc-dev] Is there a reason for short arch and host names?
Fri Jul 27 14:35:17 CDT 2012
I'm sick of truncated PETSC_ARCH in log_summary. Does anyone object to my
pushing the following to petsc-3.3? Should we just make all the fields huge
so we're guaranteed to get everything? Since pname can be as long as
PETSC_MAX_PATH_LEN, this is not a line we can reasonably limit/align.
--- a/src/sys/plog/plog.c
+++ b/src/sys/plog/plog.c
@@ -1269,7 +1269,7 @@
   PetscStageInfo     *stageInfo = PETSC_NULL;
   PetscEventPerfInfo *eventInfo = PETSC_NULL;
   PetscClassPerfInfo *classInfo;
-  char               arch[10], hostname[64], username[16],
pname[PETSC_MAX_PATH_LEN], date[64];
+  char               arch[64], hostname[128], username[16],
   const char         *name;
   PetscLogDouble     locTotalTime, TotalTime, TotalFlops;
   PetscLogDouble     numMessages, messageLength, avgMessLen, numReductions;
@@ -1311,12 +1311,12 @@
   ierr = PetscFPrintf(comm, fd, "***             WIDEN YOUR WINDOW TO 120
CHARACTERS.  Use 'enscript -r -fCourier9' to print this document
 ***\n");CHKERRQ(ierr);
"************************************************************************************************************************\n");CHKERRQ(ierr);
"\n---------------------------------------------- PETSc Performance
Summary: ----------------------------------------------\n\n");CHKERRQ(ierr);
-  ierr = PetscGetArchType(arch, 10);CHKERRQ(ierr);
-  ierr = PetscGetHostName(hostname, 64);CHKERRQ(ierr);
-  ierr = PetscGetUserName(username, 16);CHKERRQ(ierr);
+  ierr = PetscGetArchType(arch,sizeof arch);CHKERRQ(ierr);
+  ierr = PetscGetHostName(hostname,sizeof hostname);CHKERRQ(ierr);
+  ierr = PetscGetUserName(username,sizeof username);CHKERRQ(ierr);
   ierr = PetscGetProgramName(pname, PETSC_MAX_PATH_LEN);CHKERRQ(ierr);
-  ierr = PetscGetDate(date, 64);CHKERRQ(ierr);
-  ierr = PetscGetVersion(version,256);CHKERRQ(ierr);
+  ierr = PetscGetDate(date,sizeof date);CHKERRQ(ierr);
+  ierr = PetscGetVersion(version,sizeof version);CHKERRQ(ierr);
   if (size == 1) {
     ierr = PetscFPrintf(comm,fd,"%s on a %s named %s with %d processor, by
%s %s\n", pname, arch, hostname, size, username, date);CHKERRQ(ierr);
   } else {
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120727/11d8a680/attachment.html>
