[petsc-dev] Complex Cholesky
Jose E. Roman jroman at dsic.upv.es
Fri Jul 27 03:26:05 CDT 2012
El 26/07/2012, a las 21:34, Hong Zhang escribió:
> Jose :
> Then why not give a PETSC_ERR_SUP error?
> Patched 3.3 and petsc-dev.
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/ff096aff2a39
> When I find time, I'll implement MatSolve() for seqsbaij_hermitian :-)
> Hong
Thanks. I think the same error should go to MatGetFactor_seqaij_petsc otherwise my second sample run gives wrong results:
$ ./ex10 -f $PETSC_DIR/share/petsc/datafiles/matrices/hpd-complex-int32-float64 -ksp_type preonly -pc_type cholesky
Number of iterations =   1
Residual norm 1.64361
Jose
