[petsc-dev] Regression tests
Thu Jul 26 14:35:19 CDT 2012
On Thu, Jul 26, 2012 at 2:31 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Jul 26, 2012 at 2:17 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> You can tell from the primary key what it is. If the primary key is
>> wrong, it does not help you in your scenario as it could be
>> misspelled, or intended to be put in another directory. This is dubious
>> at best.
> I don't need the primary key to be "right" to have good diagnostics, I
> just need to know that the Test() declaration (which executes code at the
> time the test is created) is inconsistent. My error message tells you the
> line that is bad. This is important.
>>  We should have a discussion about whether we want to support this after
>> 3.3.
> What's the problem? Is builder.py having trouble figuring out how to link
> PETSc in general? Maybe it should use "make getlinklibs". ;-D
> Note that people occasionally ask for minimal builds for low-level
> functionality. Barry was even asking if it would be feasible to have a way
> to build only some KSPs, PCs, and matrix formats. I like that the option
> keeps us honest.
>  No no. Your original make log is in PETSC_ARCH/conf/make.log. It should
>> never be corrupted. You
>> remove the link at make.log.bkp.
> Well, that's an interesting (and confusing) idea for how it *could* work
> some day, but it's not how it currently works.
>> Same way we do in the makefiles now. It has an attribute "complex",
>> "superlu", etc.
> So what you're saying is that your system could be extended to do this?
> I'm not disagreeing, but I think my suggestion is more maintainable and
> extensible. As I said in my first reply, the differences are mostly
> cosmetic, but I think there is good reason to prefer the form I suggest.
> The important thing in either case is to have a database of tests so we can
> program behavior.
Obviously I disagree. I responded to the maintainability argument, but you
just ignored the response.
>  Some have these.
> Held separately?
Yep.
  Matt
> regressionRequirements = {'src/vec/vec/examples/tests/ex31':
>  set(['Matlab'])
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120726/90acaf2f/attachment.html>
