[petsc-dev] Regression tests
Thu Jul 26 12:21:10 CDT 2012
Builder does some of this, but I think not all, and I don't think it's as
convenient. The differences are partly syntactic. First, to add a test, you
have to add lines to a single global file (currently 1500 lines). By
creating the dictionary globally, we can't do consistency checks when the
test is declared, instead you only do it later once you have lost line
number information. You also can't build in the source directory, or
anything similar, which makes it hard for a user to split an example out
into their own toy project. Since you mess around with stdout, we are
losing warning messages (including color) and lose some Emacs M-x compile
convenience. (this can be fixed easily enough).
Note that my suggestion does not _prevent_ using a global script, but it
localizes the declaration and would make it possible to run locally.
On Thu, Jul 26, 2012 at 11:37 AM, Matthew Knepley <knepley at gmail.com> wrote:
> ./test.py build ex19
$ config/builder2.py buildExample src/snes/examples/tutorials/ex19.c
Namespace(files=['src/snes/examples/tutorials/ex19.c'], func=<function
buildExample at 0x1fa56e0>)
Building ['/home/jed/petsc/src/snes/examples/tutorials/ex19.c']
ERROR IN LINK ******************************
                   /usr/bin/ld: cannot find -lpetsc
                                     collect2: error: ld returned 1 exit
status
(maybe it doesn't work --with-single-library=0)
$ PETSC_ARCH=mpich-singlelib config/builder2.py buildExample
buildExample at 0x25dd6e0>)
(hmm, where is the executable anyway)
$ ls -ltr | tail -3
lrwxrwxrwx 1 jed users       35 Jul 26 11:57 make.log.bkp ->
/home/jed/petsc/mpich/conf/make.log
lrwxrwxrwx 1 jed users       45 Jul 26 11:58 make.log ->
/home/jed/petsc/mpich-singlelib/conf/make.log
-rw-r--r-- 1 jed users  5271714 Jul 26 11:58 RDict.log
(oh cool, it overwrote my library build with the make.log from this example)
$ cat make.log
  Loaded configure to cache: size 298004
  Compiling C files ['/home/jed/petsc/src/snes/examples/tutorials/ex19.c']
        Pushing language C
/opt/mpich2/bin/mpicc -c -I/home/jed/petsc/mpich-singlelib/include
-I/home/jed/petsc/include -I/home/jed/petsc/mpich-singlelib/include
-I/home/jed/usr/elemental-mpich/include -I/usr/include
-I/opt/mpich2/include  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -g3 -fno-inline -O0     -MMD -D__INSDIR__=
sh: /opt/mpich2/bin/mpicc -c -I/home/jed/petsc/mpich-singlelib/include
Executing: /opt/mpich2/bin/mpicc -c
-I/home/jed/petsc/mpich-singlelib/include -I/home/jed/petsc/include
sh:
        Popping language C
        Moving ex19.o to /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o
        Moving ex19.d to /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.d
Linking object ['/home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o'] into
    Pushing language C
                                Pushing language C
                                Popping language C
                                Pushing language CUDA
                                Popping language CUDA
                                Pushing language Cxx
                                Popping language Cxx
                                Pushing language FC
                                Popping language FC
        Pushing language C
        Popping language C
sh: /opt/mpich2/bin/mpicc  -o
/home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19    -fPIC -Wall
-Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline
-O0 /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o
-L/home/jed/petsc/mpich-singlelib/lib -lpetsc
-Wl,-rpath,/home/jed/petsc/mpich-singlelib/lib
-L/home/jed/petsc/mpich-singlelib/lib -ltriangle -lX11 -lchaco -lparmetis
-lmetis -Wl,-rpath,/home/jed/usr/elemental-mpich/lib
-L/home/jed/usr/elemental-mpich/lib -lelemental -lplcg -lpmrrr -lamspub
-lml -Wl,-rpath,/opt/mpich2/lib -L/opt/mpich2/lib
-Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1
-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -lmpichcxx -lstdc++ -lpthread
-lblacs -lHYPRE -lmpichcxx -lstdc++ -Wl,-rpath,/usr/lib -L/usr/lib
-lcholmod -lamd -lcolamd -lcamd -lccolamd -lumfpack -lcholmod -lcamd
-lccolamd -lcolamd -lamd -llapack -lblas -lm -L/usr/local/cuda/lib
-L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -ldl
-Wl,-rpath,/opt/mpich2/lib -lmpich -lopa -lmpl -lpthread -lrt -lgcc_s -ldl
Executing: /opt/mpich2/bin/mpicc  -o
sh:
    Popping language C
(the above output loses warnings)
$ mpich-singlelib/lib/ex19-obj/ex19 -happy-running
>> ./test.py check ex19_fas
$ PETSC_ARCH=mpich-singlelib config/builder2.py check --testnum 5
Namespace(args=[], files=['src/snes/examples/tutorials/ex19.c'],
func=<function check at 0xfe17d0>, retain=False, testnum=5)
All tests pass
(edit file, insert syntax error, re-run)
[same output as above]
>> ./test.py check ex19_\* # run all the ex19 tests
>> ./test.py check -n 16 --if '(X || Fortran) && !Complex'
How?
>> The last line would mean to run all tests requiring X or Fortran, but not
>> complex, using up to 16 MPI processes total.
>> We could preserve "make runex19_fas" in the transition period, but I'd
>> like to be able to do everything from test.py.
> builder already does all of this, and more stuff for code generation.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120726/1d49e905/attachment.html>
