[petsc-dev] MatMultHermitianTranspose
Jose E. Roman jroman at dsic.upv.es
Fri Jul 20 04:20:22 CDT 2012
El 18/07/2012, a las 17:45, Jed Brown escribió:
> On Wed, Jul 18, 2012 at 10:22 AM, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 18/07/2012, a las 15:05, Jed Brown escribió:
> > MatMultHermitianTranspose could have a default implementation in terms of the others. Then it would work in all cases, right?
> Do you mean VecConjugate(x) plus MatMultTranspose(A,x,y) plus VecConjugate(y) ??
> I guess this would work.
> In the PETSc implementation, right?
How about the attached patch?
If you agree, should I push to petsc-3.3? or petsc-dev only?
Jose
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120720/9c62be5c/attachment.obj>
