[petsc-dev] where is type(Mat) defined?
Tue Jul 17 22:51:04 CDT 2012
  If you are using Fortran modules (and being a FORTRAN lover you are :-). Then you have to rebuild the modules whenever you change these files.  Do make cmake after you edit the file
   Barry
On Jul 17, 2012, at 10:41 PM, Blaise Bourdin wrote:
> Hi,
> I am still trying to figure out how to add support for MatNullSpace with fortran data types. As I said in a previous email, adding the statement
>      type MatNullSpace
>        PetscFortranAddr:: v
>      end type MatNullSpace
> in include/finclude/ftn-custom/petscmatdef.h90
> is not enough.
> Furthermore, if I remove the corresponding statement
>      type Mat
>      end type Mat
> for Mat, I can still compile code with a statement like
> Type(Mat) :: M
> It looks like the fortran data type for Mat is defined somewhere else, but I can't figure out where. Can anybody shine some light for me?
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
